Why is the 03 down on power?
Old Feb 13, 2003 | 08:23 PM
LoneRanger's Avatar
Re:Why is the 03 down on power?
[quote author=deere nut link=board=20;threadid=10909;start=0#104026 date=1045109120]<br>Better bring your truck back. I pulled a 35 foot triple axle gooseneck with a JD 4020 on it at 50 mph. Got about 15 mpg. I get 22 mpg driving 70 with nol load. I have 4.10 gears.<br>[/quote]<br>What is your opinion about the 410 gears affect the your mpg as opposed to the 3.73 gears when noload?
Old Feb 13, 2003 | 09:23 PM
deere nut's Avatar
i have read several times on this forum there is no difference in mpg between the two gear ratios (4.10 &amp; 3.73). The 410 keeps the cummins in its sweet spot 2200-2500 at most highway speeds. I turn 2300 at 70. The adavantage of the 3.73 to me would be less engine noise at high speed and the ability to go faster. Ifyou drive over 75 a lot and dont pull much or pull heavy then the 3.73 would be better. i personally drive 70 maybe 75 max. i pull heavy loads occasisonally and would rather have too much gear than too little. I recommend the 4.10. Its not too much gear and the mpg is the same. You have that extra pulling power if you need it.
Old Feb 13, 2003 | 10:48 PM
Sarge1124's Avatar
[quote author=Dodgeclown link=board=20;threadid=10909;start=15#104446 date=1045195002]<br>OK here u go... 5o4 miles and I used 70.3 Gals.....<br><br>Now you do the MAth....<br><br><br>By the way it's not 14 or 22 mpg.....<br>[/quote]Give it up Dodgeclown, stop while you are still behind!!
Old Feb 13, 2003 | 11:00 PM
P Kennedy's Avatar
I will give you .50 on the dollar for the junk Dodge and allow you to lease that new Ford with a clear conscience. PK
Old Feb 14, 2003 | 07:33 AM
LoneRanger's Avatar
[quote author=deere nut link=board=20;threadid=10909;start=15#104432 date=1045193026]<br>i have read several times on this forum there is no difference in mpg between the two gear ratios (4.10 &amp; 3.73). The 410 keeps the cummins in its sweet spot 2200-2500 at most highway speeds. I turn 2300 at 70. The adavantage of the 3.73 to me would be less engine noise at high speed and the ability to go faster. Ifyou drive over 75 a lot and dont pull much or pull heavy then the 3.73 would be better. i personally drive 70 maybe 75 max. i pull heavy loads occasisonally and would rather have too much gear than too little. I recommend the 4.10. Its not too much gear and the mpg is the same. You have that extra pulling power if you need it. <br>[/quote]<br>Okay. 410 it is as I don't drive over 80 with the truck. If I wanted speeds faster, I guess I would look at sports cars.<br>Thank you very much<br>Dan
Old Feb 14, 2003 | 08:11 AM
spots's Avatar
xcuse me mr klown:<br>since the deeler has put three ingines in your truck and your odomeeteer reeds forewards and baak waards, yer speling and gramar is pour, you dont want to use the leemon law, and most if all the list think you are full of, poor melieage,(between -3 and 28) I will peersonally bye your truck so you kan buy a Ford. Go away........back to the Ford list where u kame from..... : : : :
Old Feb 14, 2003 | 08:26 AM
Jonesey's Avatar
Dodgeclown,
One more post with your VIN before you quit posting please. Then we can all call DC customer service and help you get some satisfaction. That's the least all of your fellow Dodge owner brothers can do.
Old Feb 14, 2003 | 08:54 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Ok guys, I think everyone is in agreement that this thread serves no purpose. Lets all move on to something worthy of discussion.
jumper
14
Apr 15, 2008 12:19 AM
sgrooms
21
Apr 8, 2008 11:17 AM
steelblitzkrieg
16
May 24, 2007 02:26 PM
Begle1
Sep 12, 2006 12:02 PM
rollsroyce1999
16
Aug 11, 2006 07:42 PM
