Who Uses a Mag Hytec DD Trans Pan??
Old Nov 30, 2009 | 11:18 PM
D45's Avatar
D45
Who out there is running a MH double deep trans pan?
727-DD should be the part number....
Any issues with the depth of the pan?
Just getting ready to order one for my trans project and wanted to make sure there was plenty of room and clearance for it....
Adds a nice 4 quarts to the system!
THANKS!
Old Dec 1, 2009 | 03:44 AM
Topper's Avatar
I do.
I had Dave put it on when he bult my trans. I like it and have had no issues at all.
See ya,
Topper
Old Dec 1, 2009 | 05:11 AM
TexasCTD's Avatar
I've been running one on mine since 15K miles. Has 125K now. No problems, very nice unit...helps keep the fluid cooler and provides 4 extra quarts of fluid. No issues with the depth.
Old Dec 1, 2009 | 09:03 AM
glocklove's Avatar
No issues with mine ether tucks up uder the cross member by about 1/2 to 3/4 of an inch so you don't catch it on anything.
Old Dec 1, 2009 | 12:46 PM
DirtEater's Avatar
I run the DD pan and have for about 45K miles. Zero issues.
Old Dec 2, 2009 | 06:48 AM
elirandolph's Avatar
No issues with mine either; go ahead and get it, its a very nice piece.
Old Dec 2, 2009 | 04:18 PM
patoka pirate's Avatar
No problems, and easy install. Mine is above the bottom of the frame so no drag issues.
Old Dec 2, 2009 | 05:32 PM
38 Cigarette's Avatar
Arrow DD user here too
No clearance issues on mine. I like the magnetic drain plug to see the debris too.
Old Dec 2, 2009 | 09:58 PM
forwardho's Avatar
I have it and it is doing fine with 35,000 miles of use. Go for it.
Old Dec 3, 2009 | 09:09 AM
pik's Avatar
pik
I agree with everyone else. Pulling my 30 foot camper, trans temps dropped 10 degrees. No issues with clearance.
Old Dec 3, 2009 | 05:04 PM
I know this wasn't the question but I wanted to mention, with the mag h rear dif cover my spare tire didn't fit in the under bed location. Could be partly because I upgraded the receiver hitch also. But I now have the spare in the bed tucked under the tool box. Stays cleaner there anyway. But I still love it and my DD tranny pan.
Old Dec 3, 2009 | 08:33 PM
justin mcfall's Avatar
PML makes a good tranny pan also...
Old Dec 4, 2009 | 03:02 AM
TexasCTD's Avatar
Hmm...I wonder why your spare won't fit with the MH rear diff. Mine fits fine.
Have you tried putting the spare on the ground...put the cradle in the hole and start lifting it........and once you have it partly lifted pull down on the rear of the tire/rim and lift up the front over the MH cover. Then finish raising it up.
Old Dec 4, 2009 | 07:53 AM
Hvytrkmech's Avatar
I have the tranny pan and the rear diff cover. I put both on the truck the week I took it home, I love both. You clearance issue with the diff cover is because you have a short bed truck. I have a mile of room with the lb.
Old Dec 4, 2009 | 12:31 PM
TexasCTD's Avatar
I................ You clearance issue with the diff cover is because you have a short bed truck. I have a mile of room with the lb.
I didn't even think about that when I made my comment, Tim. Guess that would make a difference.
EverydayDiesel
Nov 11, 2007 09:33 AM
redhornet
Jul 22, 2007 09:46 PM
texasram2500
May 21, 2007 08:01 AM
Dodgezilla
May 24, 2006 09:00 PM
Johnny
Apr 15, 2004 02:10 PM
