Mag-Hytec Double Deep Trans Pan
Old May 19, 2007 | 09:31 AM
texasram2500's Avatar
I have a 2006 2500 Mega 4x4 with auto transmission. I have a Mag Hytec Double Deep Transmission pan sitting in my garage waiting to put it on. How much ATF do I need to put back in. This wil be the first fluid change so I am not sure how much the stock pan holds. I understand that the DD Pan holds another 4 qrts extra. Also I think I read that to check the fluid level, you start engine and put it in nuetral.....is that correct.
Old May 19, 2007 | 09:35 AM
tcr's Avatar
tcr
I can't help, I have the BD deep pan, it only holds 3 qts extra. You do need to warm the tranny fluid and check on LEVEL ground in N.
Old May 19, 2007 | 12:08 PM
Turbobob's Avatar
I'm glad you posted this question!! I JUST installed my Mag-Hytec DD trans pan on my 06 Mega. The directions say it hold 9 quarts. I put in 9 quarts, and it BARELY reads on the dipstick, after driving it for about 10 minutes. The trans temp is reading 175 degrees. When I emptied the drain pan into old gallon oil bottles, it measured at almost 7 quarts (This was how much was drained from the stock pan). How much will these things REALLY hold?
Old May 19, 2007 | 12:32 PM
tufamc's Avatar
Hope this helps, I just put on a standard depth mag-hytech pan and it took 5.5qts to fill'er back up
Old May 19, 2007 | 06:40 PM
TexasCTD's Avatar
Mine held approximately 9 quarts to just drain and refill the MH DD Pan. I would just buy more than you need and start checking it after about 8 quarts or so....and keep adding until full. Probably want to check it on level ground with the gear selector in neutral.
Old May 19, 2007 | 09:01 PM
Turbobob's Avatar
After driving it around a while longer, I put in another 1 1/2 quarts to get it in between the min & max on the dipstick. That's a total of 10 1/2 quarts.
Old May 19, 2007 | 10:26 PM
Christov's Avatar
It took me a while to get mine adjusted. I have the deep sump Mag Hytec and think I used around 10 quarts. I did check mine with level ground, hot, and in neutral. Great Pan!! Expensive, but I feel worth it. High quality.
Old May 20, 2007 | 12:56 AM
Luvnacumns's Avatar
Mine took 11 to fill her back up!!! I can't get my tranny over 175 degrees... Love these pans.. I haulsed 13K on the gooseneck the other day in hilly terrain and she wouldn't hit 170 at all...
Shane
Old May 20, 2007 | 04:25 PM
kens_isb's Avatar
i'm about to install one on mine. Question is, what about the filter? Is there a spacer or something that's included for it?
Old May 20, 2007 | 07:00 PM
Thanks for all the replies..I hope to get a chance to put it on tomorrow. To answer the previous question..I ordered mine from Geno's and it came with a new gasket, new filter and the spacer to put filter lower in the pan.
Old May 21, 2007 | 08:01 AM
AlCorr's Avatar
Yes, the pan should come with a spacer.
Be sure, after filling the auto transmission, with the engine running, to run shift lever through all gears up and down a few times stopping in each gear for a few seconds, then check fluid level in neutral, on level ground. Also check again after driving.
Hetdiesel
May 19, 2009 07:54 AM
MX429
Nov 25, 2008 07:15 PM
EverydayDiesel
Nov 11, 2007 09:33 AM
MrKen
Nov 23, 2006 03:19 PM
BigBlue
Sep 30, 2005 08:27 AM
