When these Injectors Fail, What Fails?
Old 01-18-2008, 02:30 PM
rnb_cattle's Avatar
Ok,
I see these posts about failures. And I see these ebay ads for new tips all the time for the 04.5-07 CTD. Is that what is failing on these injectors, the tips?
Old 01-18-2008, 03:01 PM
Spooler's Avatar
The tips are for performance modifications. Normally what fails is the injector bodies crack spraying fuel in the valve cover area/ fuel in the oil. Also some sealing surfaces that can leak. That is what I have normally seen from on here. Every now and then you will see an injector that got stuck open, flooding that cylinder with fuel and causeing a piston meltdown. Have seen one myself and heard of a few others.
solostyle1
03-16-2008 07:38 PM
qwest
03-29-2007 08:37 PM
SPINPOSI
03-11-2007 07:35 AM
greasemonki
01-25-2007 09:41 PM
HappyGA
09-12-2006 02:16 PM
Quick Reply: When these Injectors Fail, What Fails?
