Max pressure into a VE pump? What fails?
Old Mar 7, 2007 | 04:36 PM
SPINPOSI's Avatar
Tired of searching....
Whats the Max pressure into a VE pump?
What goes wrong?
What the best reulator for this application?
Old Mar 7, 2007 | 04:38 PM
G1625S's Avatar
What goes wrong?
1-15psi
2-seal fails and the VE pumps diesel into the crankcase
3-Dave, where are you?
Old Mar 7, 2007 | 04:42 PM
18 psi seems to work OK too. When you get over 20 psi you are playing with a rattlesnake.
The front pump seal blows off, then what Greg said happens.
I like bypass regulators. They can be as simple as an adjustable check valve in a new return line. Excess pressure is just dumped to the tank.
Old Mar 7, 2007 | 04:45 PM
SPINPOSI's Avatar
Alright...I'll shoot for 18psi max....
-Jason
Old Mar 7, 2007 | 10:44 PM
Ace's Avatar
Ace
I came up with what I think is a good way to provide more fuel without worrying about excess VE inlet pressure. Check out the post I just made titled "Fuel System Upgrade Pics."
Old Mar 8, 2007 | 01:33 AM
bgilbert's Avatar
A good red loctite job on the front seal or a retainer fabbed up will take care of big pressure. KTA fabbed a retainer and runs upwards of 60psi inlet pressure with no issues, only big HP. I've run up to 30psi so far with only red loctite and I've either been lucky or something.
Here is the regulator I use, AEI-13204: http://store.summitracing.com/partde...5&autoview=sku. Aeromotive A1000 electric pump.
Ace is right, it's more about volume than pressure.
Old Mar 8, 2007 | 07:16 AM
SPINPOSI's Avatar
Would this one work?
The low pressure spring is 3-20 psi
Or is 20psi pushing my luck.......
Old Mar 8, 2007 | 03:39 PM
That would work, but you really don't need to spend that much money. All you need is an adjustable check valve in the bypass line.
Old Mar 8, 2007 | 04:46 PM
SPINPOSI's Avatar
Dont mean to be a pest ....but ...could someone shoot me a part number of a check valve that your using or is known to work on this setup?
I seem to be check valve info impaired....
-Thanks a Million
-Jason
Old Mar 8, 2007 | 05:44 PM
mhuppertz's Avatar
I would like more info on what KTA did... please???
Old Mar 9, 2007 | 08:07 PM
Allegedly this one works.
http://www.swagelok.com/search/produ...part=B-4CPA4-3
I got the valve I'm running from GDP, I don't know where he got it.
Old Mar 10, 2007 | 12:51 AM
BearKiller's Avatar
Where are you guys returning the fuel from those return style regulators?? back into the existing return line, or adding a dedicated return line??
Thanks.
Old Mar 10, 2007 | 03:16 PM
I have a new return line that tees into the filler neck vent.
Old Mar 10, 2007 | 03:36 PM
Fergavs's Avatar
I'd also like info on knowing how to help the VE take high volume and 60psi.
Old Mar 10, 2007 | 06:56 PM
Ace's Avatar
Ace
The best way to get more volume throught the fuel system is to incease the size of the fuel lines from the tank and reduce any restrictions like pressure drop though the filter. I'm not sure why you would want to go that high on the pressure. I think that would be a bad idea. The injection pump is only going to flow as much fuel as the injectors need, providing it has enough supply. That supply somes from flow/volume at a given pressure. The VE is designed for that fuel to appear at the inlet around 10-15psi. I doubt ncreasing the inlet pressure much beyond that will change how it delivers fuel to the injectors, except possibly blowing a seal.
