never fails!!!!!
Old Mar 16, 2008 | 07:07 PM
solostyle1's Avatar
never fails!!!!!
after being told from the dealership that my intank lift pump was bad, i turned down there offer and fixed it myself by installing a airdog setup. start the truck and i still have the same problem. truck will run for a minute or so and then die. it will idle fine until i put it in gear and then it dies. i check the codes and im getting the p0251 code "CP3 Pump Regulator Control" this truck is nothing but a HUGE pain lately! any input to what this is?
Old Mar 16, 2008 | 07:38 PM
vzdude's Avatar
DTR's 'Go to Guy'
P0251-CP3 PUMP REGULATOR CONTROL
For a complete wiring diagram Refer to Section 8W.
When Monitored:
When the ignition is on.
Set Condition:
The ECM detects a discrepancy between the PWM supplied to the Electronic Fuel Control Actuator and the PWM returned from the Electronic Fuel Control Actuator.
Possible Causes
FUEL PUMP
(K604) FUEL CONTROL ACTUATOR DRIVER OPEN
(K65) RETURN CIRCUIT OPEN FROM FCA TO ECM
(K604) FUEL CONTROL ACTUATOR DRIVER CIRCUIT SHORTED TO EXTERNAL VOLTAGE
(K65) FUEL CONTROL ACTUATOR RETURN CIRCUIT SHORTED TO EXTERNAL VOLTAGE
(K65) FCA RETURN CIRCUIT SHORTED TO (K604) FCA DRIVER CIRCUIT
(K604) FUEL CONTROL ACTUATOR DRIVER CIRCUIT SHORTED TO GROUND
(K604) FUEL CONTROL ACTUATOR DRIVER CIRCUIT SHORTED TO ANOTHER CIRCUIT
(K65) FUEL CONTROL ACTUATOR RETURN CIRCUIT SHORTED TO ANOTHER CIRCUIT
INTERMITTENT CONDITION
ECM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
Diagnostic Test
1. FUEL PUMP
Ignition on, engine not running.
Disconnect the Fuel Control Actuator (FCA) harness connector.
Connect an incandescent test light across the Fuel Control Actuator driver circuit and the Fuel Control Actuator return circuit at the fuel control actuator harness connector.
Observe the test light.
The ECM will perform a self test of the circuit which should momentarily flash the test light brightly, one time, approximately 20 seconds after being connected.
note: Check connectors - Clean/repair as necessary.
note: Compare test light brightness to that of a direct connection to the battery.
Did the light flash brightly?
Yes
Replace the Fuel Pump.
Perform POWERTRAIN VERIFICATION TEST (DIESEL). (Refer to 9 - ENGINE - STANDARD PROCEDURE)
No
Go To 2
2. (K604) FUEL CONTROL ACTUATOR DRIVER OPEN
Turn the ignition off.
Disconnect the ECM harness connectors.
Measure the resistance of the FCA driver circuit between the electronic fuel control actuator harness connector and the ECM harness connector.
Is the resistance less than 10 Ohms?
Yes
Go To 3
No
Repair the (K604) Fuel Control Actuator Driver circuit OPEN.
3. (K65) RETURN CIRCUIT OPEN
Measure the resistance of the (K65) return circuit between the FCA harness connector and the ECM harness connector.
Yes
Go To 4
No
Repair or replace the engine wiring harness.
4. (K604) FUEL CONTROL ACTUATOR DRIVER CIRCUIT SHORTED TO EXTERNAL VOLTAGE
Measure the voltage between the (K604) FCA driver circuit in the FCA harness connector and battery negative.
Is the voltage greater than 1 volts?
Yes
Repair the (K604) FCA driver circuit shorted to external voltage.
No
Go To 5
5. (K65) FUEL CONTROL ACTUATOR RETURN CIRCUIT SHORTED TO EXTERNAL VOLTAGE
Measure the voltage between the (K65) FCA return circuit in the FCA harness connector and battery negative.
Yes
Repair the (K65) FCA return circuit shorted to external voltage.
No
Go To 6
6. (K65) FCA RETURN CIRCUIT SHORTED TO (K604) FCA DRIVER CIRCUIT
Measure the Resistance between the return circuit in the FCA harness connector and Driver circuit.
Yes
Repair the (K65) FCA Return circuit shorted to (K604) FCA Driver circuit.
No
Go To 7
7. (K604) FUEL CONTROL ACTUATOR DRIVER CIRCUIT SHORTED TO GROUND
Measure the resistance between the (K604) FCA driver circuit in the FCA harness connector and battery negative.
Yes
Repair the (K604) FCA driver circuit shorted to ground.
No
Go To 8
8. (K604) FUEL CONTROL ACTUATOR DRIVER CIRCUIT SHORTED TO ANOTHER CIRCUIT
Measure the resistance between the (K604) FCA driver circuit in the ECM harness connector and all other circuits in the ECM connectors.
No
Go To 9
Yes
Repair the (K604) FCA driver circuit shorted to another circuit.
9. (K65) FUEL CONTROL ACTUATOR RETURN CIRCUIT SHORTED TO ANOTHER CIRCUIT
Measure the resistance between the (K65) FCA Return circuit in the ECM harness connector and all other circuits in the ECM connectors.`
No
Go To 10
Yes
Repair the (K65) FCA Return circuit shorted to another circuit.
10. ECM
Reconnect the ECM harness connectors.
Disconnect the Electronic Fuel Control Actuator connector.
Connect an incandescent test light across the Fuel Control Actuator driver pin and the Fuel Control Actuator return wire at the fuel control actuator connector.
Yes
Refer to the INTERMITTENT CONDITION Symptom (Diagnostic Procedure). (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
No
Replace the ECM.
dtrkstan
Feb 27, 2009 05:10 PM
iweb
27
Jun 13, 2007 07:57 AM
redneckonthenet
Feb 28, 2005 10:01 AM
mymaur
Jan 14, 2003 08:29 PM
Tackdriver
Jan 9, 2003 06:11 PM
