View Poll Results: Which oil filter
Amsoil
10.50%
Fleetguard
58.56%
Fram
2.76%
Mobil 1
3.87%
24.31%
Voters: 181. You may not vote on this poll
What oil filters are we running?
Old Jan 5, 2009 | 08:00 PM
  #31
Lubemanager's Avatar
It does not matter what you use for a full flow engine oil filter, they do not do much but give you a warm fuzzy feeling. If you were to cut one open, you would not see much of anything, unless you are dumping dirt in with your new oil. If you want to clean your oil, you must filter down to 1 to 2 microns, which is much finer then the average of 15 to 25 micron, nominal rated, that most full flow filters are.
Old Jan 5, 2009 | 08:08 PM
  #32
md-rebel's Avatar
Originally Posted by scottsjeeprolet
Fleetguard Stratapor from Genos.
Same here w/Rotella
Old Jan 5, 2009 | 08:52 PM
  #33
BroncoAZ's Avatar
I keep eyeballing the amsoil bypass filter setup for this reason.
Old Jan 5, 2009 | 09:44 PM
  #34
trik396's Avatar
I've run a Motorguard bypass filter and an Oilguard bypass filter.
I now run the Amsoil bypass just because it's easiest to swap filters.
Any bypass filter is better than no bypass filter.
Old Jan 5, 2009 | 09:58 PM
  #35
Seabiscuit's Avatar
filter
Mobile One
Old Jan 6, 2009 | 02:19 PM
  #36
bradler's Avatar
Originally Posted by gibbs6017
i use the k&n is there any reason no one else is??
Other than not being on the list of "approved filters", I was told the K & N may not have an anti-drain back valve. So I guess the oil can drain back through the filter after you shut down, resulting in dry starts....
Old Jan 6, 2009 | 03:04 PM
  #37
BroncoAZ's Avatar
The literature I read for the K&N showed that it is equipped with an anti drainback valve. The K&N and Mobil 1 filters are very similar, but in some applications the 1" nut on the K&N filter makes changing it much easier. I've used them on my Bronco for years.
Old Jan 6, 2009 | 03:29 PM
  #38
DBLR's Avatar
I have a Fleetguard on it now but the next one will be a Donaldson high efficiency being its rated at 15 micron and the Fleetguard Stratapore is only rated 25 micron and others are even higher (poorer) like the Pureone that states on the box that its rated at 40 micron I've been told the Mopar oil filter is made with standard paper media so it is not the same as a Fleetguard Stratapore that has synthetic media. Being its made with cheaper filter media is why you can buy a Mopar filter at Walmart for $9.95 or less.
For fuel filters I use the Baldwin PF7977 5 micron, but if I could not get one then I would use the Fleetguard Stratapore being it meets the minimum 7 micron requirement that both Dodge and Cummins put in to effect back in June of 2006.
DodgeCowboy
Jul 23, 2008 10:12 PM
bcfitzsimons
Jun 26, 2008 12:17 PM
staarma
28
May 1, 2008 11:10 AM
fitzydog
Oct 12, 2007 10:23 AM
kelley15
Aug 20, 2007 04:52 PM
