What injectors do I have?
Old Jul 20, 2013 | 06:29 PM
I.Y.A.A.Y.A.S's Avatar
I recently bought the truck in my sig used. The dealer had the injectors replaced. I have asked dealer what was put in. He talked to the shop that did it but not the actual mechanic. the only info he was able to get is that they are Higher horsepower Bosch injectors. Any body have clue what these could be?How hard would it be to pull one out and check it? My truck smokes like a coal train and I'm trying to figure out if a swapping in a used 351 turbo would be big enough.
Old Jul 21, 2013 | 05:26 PM
Anybody have a clue
Old Jul 21, 2013 | 06:17 PM
madhat's Avatar
Administrator/Jarhead
Man, you'd have to pull one and send it to a shop... not even sure what would happen then.
I don't see any gauges in your sig... do you have an EGT gauge?
Old Jul 22, 2013 | 01:14 AM
I know I need one, it's high on the growing list of things the truck needs. for now I just drive it easy and I'm not planning on towing my fiver until I get one.
Old Jul 22, 2013 | 03:03 PM
StealthDiesel's Avatar
As per your other thread (https://www.dieseltruckresource.com/...e-t312981.html) have you confirmed that the firmware in your ECM is stock?
This is a logical 1st step before you start removing injectors.
An aftermarket program in your ECM could account for the majority of the smoke.
Old Jul 22, 2013 | 06:40 PM
Had he truck checked by dodge mechanic today. He said on an 03 he couldn't see if the programming had been messed with. He could flash but since I spent 330 for them to fix another problem I will Putt off having it flashed for another day. The mechanic thinks the injectors might be Bosch stage 2 that are for the HO. He said I could pull the valve cover and should be able to see the injector part number without pulling the injector.
Old Jul 23, 2013 | 11:06 AM
I still think that flashing your ECM back to stock to confirm that an aftermarket programmer is not loaded is a better 1st step than messing with your injectors.
The only way to confirm what size injector nozzles are installed in your truck is to remove them and have them flowed and tested by a reputable CR injector shop. Exergy or DDP.
Any part numbers on the injectors or nozzles would be irrelevant since they could be modified.
Old Jul 24, 2013 | 02:01 AM
Thanks, I'll get it flashed a couple paychecks from now.
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
