Turbo Noise
Old Jul 30, 2009 | 07:53 PM
JADAYSMITH's Avatar
Turbo Noise
OK i towed my 26ft 9000lb toyhauler about 500 miles this past week, pulled great, but when im on it up a grade the turbo starts making a noise like a teakettle as soon as i pull the grade noise goes away ?????????
Old Jul 30, 2009 | 09:13 PM
NickBeek's Avatar
What year truck is it? Is it just a turbo whistle or does it sound like there is a leak somewhere
Old Jul 31, 2009 | 09:33 AM
JADAYSMITH's Avatar
2004.5 2500 Not a turbo whistle its a noise other than that just when im pulling hard up a grade it comes on and then goes away after i pull the grade and then i am off off the gas. its a high pitched schreech like a tea kettle almost??
Old Jul 31, 2009 | 09:35 AM
randallp84's Avatar
It may not be coming from your turbo. If I had to guess without hearing it myself, a "teakettle" noise sounds like a timing issue.
Old Jul 31, 2009 | 09:44 AM
JADAYSMITH's Avatar
truck is totally stock other than 4" straight and boost fooler but it made this noise before boost fooler
Old Jul 31, 2009 | 09:45 AM
JADAYSMITH's Avatar
truck is totally stock other than 4" straight and boost fooler but it made this noise before boost fooler 40000 miles
Old Jul 31, 2009 | 11:43 AM
randallp84's Avatar
Lol, sorry, I was thinking of a coffee maker for some reason. After remembering what a teakettle sounds like, I would have to guess boost leak.
Old Jul 31, 2009 | 02:40 PM
JJPage's Avatar
Boost leak! check all your charge hoses for loose clamps, holes, etc.
You may have to build an adapter that you can fit over the intake on your turbo. I built one from a piece of hose off an old intake, and a 4"(dia) plastic pvc plug from Home Depot. Drill a hole into the side of the square "nut" on the end of the plug to accept a schrader valve, if you drill it out the end, you will find it will not fit without removing your oil filter.... I found this out.
Clamp this over your turbo, and set your compressor to 35#, you should find the leak quick enough.
Old Jul 31, 2009 | 02:56 PM
JP-4.5's Avatar
10-4 on the boost leak. Mine did the exact same thing once and it was just a loose clamp. Tightened it up and all was well..
Smkn600CTD
May 22, 2012 07:21 PM
Ada381
Feb 10, 2008 07:58 AM
ShowMe06
27
Jan 4, 2008 11:47 AM
powerstrokethis16
Mar 9, 2003 09:40 PM
Grampaw
Nov 20, 2002 09:36 AM
