turbo noise
Old Mar 9, 2003 | 04:23 PM
powerstrokethis16's Avatar
turbo noise
I have a mostly stock '99 24v with 75,000 miles. When i am am going at a constant speed around 65 or faster my turbo makes a popping sucking sound but when the truck is under load while accelerating it does not make the sound. the only thing i have done is put a k/n, drilled holes in the air box, 4" turbo back ATS exhaust, and a 65 hp bd chip.
Old Mar 9, 2003 | 04:26 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:turbo noise
Have you checked the exhaust manifold bolts for proper torque?
They are very prone to back off and even fall out.
There is a TSB on this.
NAIL BENDER's Avatar
Re:turbo noise
Could you possibly have a boost leak?
Old Mar 9, 2003 | 09:19 PM
Re:turbo noise
thanks, I will be sure to check for a boost leak and manifold bolt torque
Old Mar 9, 2003 | 09:40 PM
Marine's Avatar
Veteran: Marine Corp
Re:turbo noise
You might want to take the turbo inlet hose off and look at the turbine shaft. Look for excessive play (up/down, in/out) and any deformity on the blades.<br><br>Mike
Smkn600CTD
May 22, 2012 07:21 PM
Ada381
Feb 10, 2008 07:58 AM
ShowMe06
27
Jan 4, 2008 11:47 AM
Maddog
Jan 2, 2003 09:57 PM
Grampaw
Nov 20, 2002 09:36 AM
