Truk failed to start again -35 celcius?
Old Dec 23, 2008 | 11:47 AM
sallyman1's Avatar
2nd time in a week truck failed to start. last time i drained fuel filter canister and filled it halfway with diesel antigel and put charger on it. it then started. this time same temperature (-35 C) and no go again. it was plugged in for 9hours and even the cylinder head feels warm.it cranks a while but slower (obviously from cold). i put charger on again (10 amp).ill try it later.
batteries are still factory from 04. maybe its time to get rid of them. i have no access to a battery tester but illl leave it on a 2 amp charge all day.
Old Dec 23, 2008 | 11:55 AM
klx650a2's Avatar
It sounds like you have fuel gelling issues. Where are you and where do you get your fuel? I fired mine up at -35 yesterday, plugged in and she started no problems...
Old Dec 23, 2008 | 01:25 PM
sallyman1's Avatar
gelling was right. i opened up my fuel filter canisyter drain and nothing came out. then i left it open and turned my key forward so i could purge fuel out of it. then a good stream came out. it then startd
Old Dec 23, 2008 | 02:17 PM
Valv's Avatar
Dump a couple of gallons of kerosene or 911 in your tank and run truck for 1/2 hour to get it all into the fuel system. You don't have winter blended diesel, it will gel up again as soon as you get on a highway. Where are you located ?
Old Dec 23, 2008 | 04:02 PM
Spooler's Avatar
Holy Cow, you are having a heck of a time keeping it from gelling. You may need to buy your fuel somewhere else or run an antigel additive.
Old Dec 23, 2008 | 10:08 PM
bensdad_canada's Avatar
my step dads 03 just did the same thing but twice on the same tank of fuel.the first time he coaxed the truck home and threw in a bottle of diesel melt and it cleared up,but going into town yesterday the truck just up and quit on the side of the highway in -39deg celcius weather.this time it took diesel melt and a new fuel filter to get her going again.at that temp a person could set a record for the fastest fuel filter changeout,especially when the big trucks go by and the wind chill is -some gosh awful temp.
bannerd
Aug 23, 2015 04:51 PM
JARHEAD
Jun 7, 2012 09:01 AM
Crallscars
15
Jul 3, 2011 12:20 PM
ocelot777
Sep 7, 2010 02:33 PM
md11jetdriver
14
Oct 26, 2004 02:01 PM
