Truck Shut off while driving down road
Old Dec 18, 2005 | 01:48 PM
Evangelist2005's Avatar
Post Truck Shut off while driving down road
While driving down the road the truck shuttered like it wasn't getting fuel then cut off, I tried to restart and it did but shut right off. I tried to start several more times but it would not take. The starter is fine and the cranking power is fine. Sounds like a fuel problem but I had a half of tank. Can you help???? Is it the Pump? I have 50K on this truck with no other problems...
Old Dec 18, 2005 | 01:54 PM
Big Deezul's Avatar
crack the filter lines and see if fuel comes out when you bump the starter
Old Dec 18, 2005 | 02:01 PM
Geico266's Avatar
We need more info. What year is the truck? How cold is it outside. When was the last time you changed the fuel filter?
You need a fuel pressure guage ASAP.
Old Dec 18, 2005 | 04:05 PM
It is a 2004 HO, and it was probably about 40F outside. I don't think I have ever changed the filter to be honest with you, my fault I will keep it changed from now on. I had it pickuped up by roadside assistance and hopefully the 70K mile warranty will covers the problem. I just thought you all may know what was wrong for it to show no symptoms of trouble then quits.
Old Dec 18, 2005 | 04:26 PM
Geico266's Avatar
Sounds fuel related for sure. Could be the filter, or more likely the lift pump. Should be covered under warranty.
Old Dec 19, 2005 | 11:22 AM
bigblock2stroke's Avatar
50k and no filter change?
As you are probably now realizing, that is likely the problem.
15k mile interval on fuel filter.
I doubt they will cover it but let us know.
Old Dec 19, 2005 | 11:58 AM
rementa's Avatar
lift pump.
Old Dec 19, 2005 | 12:10 PM
rockdonon's Avatar
Bad Lift Pump
Just had the same happen to me. (04 with 35,000)
Mine was covered under emissions warranty.
They will put on a retro fit in tank kit.
Expect a couple of weeks in the shop. (They are WAY BACK/ORDER.)
Good Luck
Diesel Jeff
Aug 8, 2021 04:01 PM
randyswelding
Feb 9, 2009 10:40 PM
gst mike
Feb 19, 2008 12:13 PM
electrifried
Jun 16, 2005 11:06 AM
dodge power
Oct 3, 2003 10:02 PM
