Cold Morning Starts
Old Dec 19, 2005 | 08:58 AM
TIM RYDEN's Avatar
Cold Morning Starts
Started my truck the other morning. It was about 7*F - truck was not pluged in. Once the truck fired it went right up to 1000 rpm and ran ruff for about a minute or so. After that time the ruff idle went away and it ran smooth at 1000 rpm not much smoke. Is this normal? I thought I heard some one say that these engines run on three cylinders when its a cold start... Maybe I was hearing things....
Tim
Old Dec 19, 2005 | 09:30 AM
SBishop's Avatar
Normal operation when cold. Does not run on three cylinders.
Old Dec 19, 2005 | 10:28 AM
TPilaske's Avatar
My 02 would shutdown 3 cylinders when it was really cold out... don't know if these newer ones do that or not...
Tony
Old Dec 19, 2005 | 11:15 AM
bigblock2stroke's Avatar
Tony
How do you know?
Old Dec 19, 2005 | 12:18 PM
TPilaske's Avatar
Originally Posted by bigblock2stroke
How do you know?
It would go into high idle and then if it was really cold out, the engine would make a completely different sound after a minute or so of high idling, almost sounded like when the exhaust brake was on...
Here's the TSB for that: http://dodgeram.info/tsb/2001/18-019-01.htm
and here is a quote from it:
"Additionally, if Intake Manifold Temperature (IMT) is less than -9°C (15°F), and all of the parameters above are met, three of the cylinders will be shut off upon reaching 1200 rpm, creating a slight change in engine sound which is normal. This allows the engine to create increased heat in the cooling system, allowing more rapid engine warm up and cab heating."
Tony
mstep3
17
Nov 3, 2008 06:48 AM
03/5.9/CTD
Jul 8, 2008 02:51 AM
Calgary Roofer
Jan 3, 2008 11:52 PM
decepticon4ever
Mar 19, 2007 12:55 AM
nebuniRAM
Aug 26, 2005 03:06 PM
