99 CTD, truck died while driving down the road.
Old Feb 18, 2008 | 09:51 PM
gst mike's Avatar
Driving home from work the other night and the truck just died, all electricals working just fine just no engine. Motor cranks but wont fire.
I brought a code reader from work tonight figuring I would have a ton of codes but to my surprise none.
Truck has 220k on it.
4" Exhaust
Edge comp box
Any idea's?
Mike
Old Feb 18, 2008 | 10:17 PM
1qckdodge's Avatar
Can you hear the lift pump run if you just bump the key? do you have a fuel pressure gauge? the lift pump should run for 25 seconds if you bump the key, if not then thats your 1st problem, also did you check all relays? I do believe you have one for the fuel pump under the hood, as well as for the lift pump, you can also crack a fuel line and crank to see if any fuel comes out, if the lift pump does in fact work and you crack a line and get nothing, then I would suspect a VP, this is just my .02, goodluck, one more thing, if your Comp is tapped then unhook it and try to start it again.
Old Feb 18, 2008 | 11:16 PM
ramlovingvet's Avatar
DTR'S Chaplain
being a 99 I see a VP-44 in your future.
Old Feb 19, 2008 | 12:13 PM
smokinram99's Avatar
it seems to be like on my 99 2500...4months ago...VP44 died when I driving down the highway at 50mph....truck shut off and never restart, all electrical ok, Lift pump work
Rob
Relentless Man
15
Mar 23, 2009 04:02 PM
leadvilleram
Dec 29, 2008 05:59 PM
13ALPHA
Dec 6, 2007 02:56 PM
Evangelist2005
Dec 19, 2005 12:10 PM
electrifried
Jun 16, 2005 11:06 AM
