Transmission problem
Old Feb 14, 2009 | 07:48 AM
aggie06's Avatar
The other day my truck decided like it wanted to stick in gear and keep pulling forward as I tried to brake. If I hit the tow on/off switch it would finally down shift. I took it to a transmission shop and they said it didn't throw any codes, but after driving it around it did the same thing. The guy said it is most likely an electrical problem, and they will have to drop the pan to determine exactly whats wrong. Does anyone have any experience with this problem, and know what I may be looking at as far as repairs? The truck is an stock 05 QC 4wd with 48000 miles. The mechanic said he has seen this problem many times, and it depends on how much damage has been done already.
Old Feb 14, 2009 | 06:31 PM
white Lightning's Avatar
sounds to me like the clutches are junk....take it to a dealer...they know best and can get the parts unless you want to upgrade to aftermarket parts.... have you had it since new?? if so when was the last time the fluid was changed??
Old Feb 14, 2009 | 07:58 PM
dozer12216's Avatar
Does it upshift normally?? If this is correct, the governor pressure solenoid is sticking open for high gov pressure. Should be less than .5 psi at stop. Can be measured with gauge per FSM.
Old Feb 14, 2009 | 09:11 PM
aggie06's Avatar
It upshifts noramlly, but it won't downshift once it does.
Old Feb 15, 2009 | 09:54 AM
gmctd's Avatar
Acts like the TCC clutch is sticking, due to necessity of switching tow\haul in-out\off-on
Dauntless
15
Aug 30, 2016 08:37 PM
TGCTD
Jun 25, 2004 09:47 PM
dogman
Dec 27, 2003 07:06 PM
jec3
Jun 9, 2003 01:35 PM
NWDave
Nov 24, 2002 09:25 PM
