DEXRON 3w/Lubeguard vs. ATF+4
Dex III does not have additives, heat protection, lube capability, detergent action, friction modifiers, that ATF+4 has. Why do you need to add snake oil if it was as good. JMHO of course. Not to mention the mercon additive if it is included.
All Dave is trying to tell you is that you won't notice a difference in performance, durability, temps etc. and it is less expensive. The Lubegard is good stuff.
With either one, you should drop your pan every 15K and change your filter. I normally change my Dex III and Lubegard at 15K too. I talked with Dave since someone gave me a case of ATF+4.. he said at 15K, drain +4 in clean container, change filter, put +4 back in for 15K more. The real issue is the filter... Dave said those filters really filter well and will kill a tranny quicker than anything else.
Robert Rausch
14
Jun 28, 2011 03:12 PM
royta
Mar 11, 2010 08:03 AM
