Strange noise
Old Jul 6, 2005 | 12:02 PM
PADZZ's Avatar
Strange noise
I have a weird sound coming from my left front wheel. Sounds like I have a loose rock in the wheel cap. Could it be a bearing issue? Haven't pulled the cap to check if there is a rock in there.
Old Jul 9, 2005 | 11:51 AM
bauer500's Avatar
Change the caps around, put it on the right rear. Mine was doing the same thing, I switched the caps around and now there is no sound...
Old Aug 5, 2005 | 09:10 PM
snapp919's Avatar
I have the same problem and it is driving me nuts, although mine sounds like a nail in the tire. I haven't tried moving the caps around, but if that was the problem it would just put the noise somehere else.
Old Aug 5, 2005 | 09:34 PM
Geico266's Avatar
Sorry to tell you this but the bearings are shot, you'll need to take it to the dealer for warranty work. Even if you switch center covers its just a temporary fix. The cover applies just enough force to tighten the bearings for a little while. You can also add relative bearing grease to solve the problem for good. If you find a rock in the center cap leave it in there. Its suppose to be there for balancing, in fact add acouple more for better balancing.
Old Aug 18, 2005 | 10:48 PM
bauer500's Avatar
Thats BS, switch the caps around, trust me......
Old Aug 19, 2005 | 08:03 PM
Geico266's Avatar
Old Aug 20, 2005 | 11:06 AM
PADZZ's Avatar
Thanks for the replies. I'm pretty sure it's the caps too. I can't get them off from the oustside, so I'll wait til I get them rotated and have 'em switched around.
Old Aug 20, 2005 | 07:23 PM
pullin hard's Avatar
i have the same noise, and i don't run the factory wheels and centre caps.
i have narrowed it down to bad u joints in the axles or a bearing going bad, not sure which one i want it to be as this is going to get expensive!!!!!
Old Aug 22, 2005 | 12:11 PM
Raminspeed's Avatar
Sounds like the nut behind the wheel is loose (Steering wheel that is). LOL
Old Aug 22, 2005 | 12:30 PM
snapp919's Avatar
I found out the clicking sound coming from the front drivers side was my outer rim cracking due to the pressure of the 315's, I have the chrome stock wheels.
torq
19
Dec 30, 2005 05:59 PM
heavyg
Jun 24, 2003 07:43 AM
DarrellB
Mar 3, 2003 06:26 PM
Gregor
Dec 3, 2002 12:18 AM
heavyg
Oct 25, 2002 05:06 AM
