Stanadyne Fuel Pump & Filter
Old Sep 23, 2005 | 05:01 PM
Goggleyed's Avatar
Has anyone installed the Stanadyne filter and pump combo?
It has a single 5 micron filter with an inline pump that is rated at 40GPH (at up to 10 vertical feet) and will push 15psi dry. There is a site bowl screwed into the bottom of the filter to watch for water.
What I like about this package is that it looks very sturdy, filters to 5 microns and is small enough to mount under the hood (over by the intake manifold).
The FASS units are pushing many more GPH but I don't know at what PSI. Is 95GPH really required?
Will this Stanadyne unit supply sufficient fuel to the CP3 (through the existing lift pump and filter) for my Hot Juice?
Is 15psi sufficient to push a limited amount of fuel past a failed stock lift pump and filter to limp home (assuming the pump pushes at least 15psi wet also)?
BTW - It's only $199.
xxwildbillxx
Sep 26, 2011 09:38 PM
Lee S
Jul 26, 2005 12:20 AM
caleb c.
Apr 22, 2005 06:24 PM
tony
Jan 23, 2005 06:23 PM
Ryan
Aug 11, 2003 09:40 AM
