Stanadyne Fuel Manager??
Re:Stanadyne Fuel Manager??
Ryan,
If you are having fuel pressure problems I would first order the 8 AN line system from Rod at Wildcat Diesel. I had 275's and a Edge Drag Comp and my pressure at idle was 13.5 psi and at WOT never went below 10 psi. I installed the Stanadyne Fuel system and my pressure at idle was 21psi and never went below 13psi. Then I installed Mach 3 Edm's and I still have 21psi at idle but my pressure at WOT drops to 0psi. I ran a 9.17 1/8th mile but I think my volume of fuel not my pressures are the problem. Talk to Rod and tell him your mods and he should be able to help you.
By the way, the install on the Stanadyne system is fairly simple. The wiring is the only difficult part.
I hope this helps!
Meacham Evins :
http://www.wildcatdiesel.com/
I hope this helps!
Meacham Evins :
Guest
Posts: n/a
I had the Stanadyne fuel manager on my truck with a 30 micron filter on it. It died after about 45 days on my truck. I'm not saying it's a bad product. I may have received a bad one or something, I don't know. BUT, If I put another pump on my truck, itll be a Holly Blue or something like that next time.
xxwildbillxx
Sep 26, 2011 09:38 PM
gmctd
Feb 4, 2008 01:11 AM
One Way
43
Apr 27, 2005 11:31 PM
B1 Power Wagon
May 19, 2003 09:00 AM
