Squeaking sound while turning ?
Old Aug 4, 2008 | 06:48 PM
coobie's Avatar
I have around 70,000 miles on the OD on my 2004.I had the u-joints replaced at 30,000 miles with the spicer greasable ones.When I turn the steering wheel I get a slight squeaking sound,could this be front ball joints or u-joints?Thanks,coobie
Old Aug 4, 2008 | 09:19 PM
JP-4.5's Avatar
What u-joints did you replace? Front axle?
I recently had a similar noise and I had a front axle u-joint bad. I also change my ball joints out as they also were over due. No sqeak now...
The front axle ujoint if they are stock you can tell by the rust that will be coming out of the joint. Jack the front end up and use a pry bar to lift on the tire to see if there is paly in the ball joints..
Also be sure to check the tie-rods while you are tearing it apart...
Old Aug 5, 2008 | 07:44 AM
truckbouy2's Avatar
From: Frozen Northern Minnesota, Darn Close To Where Perma-Frost Begins...
Could be the wear indicators on the brake pads, OR the pads just sometimes drag and squeak depending on use, weather, dirt, and or rust.....
Old Aug 5, 2008 | 03:56 PM
coobie's Avatar
Rear axle u-joints were replaced with greasable spicers at 30,000 miles.
Old Aug 6, 2008 | 02:54 PM
coobie's Avatar
I ended up having the same problem.Front axle u-joints were bad,replaced both sides.No more squeak.coobie
JoeDiesel
Jan 16, 2011 10:03 AM
MegaMagoo3500
Sep 6, 2008 11:31 AM
sickandtwisted
Jul 29, 2007 08:16 AM
MK4288
Feb 18, 2004 03:30 PM
ken962500
Dec 4, 2003 01:10 AM
