slight knocking, then sounds normal when on the throttle
Old Jul 5, 2013 | 08:44 PM
hot_runner58's Avatar
03 cummins Truck started knocking a few thousand ago, had injectors checked and replaced all of them, quieted it down a ton, but not completely. when just at cruise speed you can here it, but once I get on the throttle it goes away. It does the same knocking when it's cold, and I get on it pulling into traffic, until the truck seems to get fuel and take off. I turned up the pressure on the f100 and it didn't seem to make a difference. It does it really bad when I have the Ramifier plugged in and the truck isn't up to temp and I get on it even 1/4 throttle. It's like it's trying to get fuel, but it isn't getting it. Once the truck is up to temp, it still knocks a little, but it has no problem scooting down the road even with the ramifier on and taking off from a dead stop. I have tried re-programming the smarty to diff. levels, doesn't really make a difference. I never noticed the knocking before the injectors went out. After reading a thread below about a possible tired CP3, it made me wonder if that could be a culprit, or if it's just my mind worrying me, because once the truck is warmed up it has no problems. I asked in another thread if possibly I'm trying to ask to much of my cp3 with my mods, and was re assured it should handle them, so I crossed that off of possibilities as long as the pump is healthy.
Old Jul 5, 2013 | 09:20 PM
jhenson's Avatar
Do you know what your rail pressure is? Could be the FCA on the backside of the pump acting up.
Old Jul 6, 2013 | 01:55 PM
I had read that possibility on the thread you have going on, just wasn't sure if that could affect it.... But, I don't have my pressure gauge installed yet. Shame on me I know. Is there a way to bypass the FCA?
Old Jul 7, 2013 | 10:11 PM
jhenson's Avatar
No, the ECM needs to read the FCA in order to prompt pressure ramp up to the rail.
Old Jul 10, 2013 | 04:35 PM
Sittingbull2's Avatar
I haven't posted in a long while but if you haven't put and aux. fuel water separator on your truck you ought to. Because any kinda trash/water gets pass your stock filter in has a tendency to screw with the FCA Valve. It will make codes come up saying High/Low Pressure on the fuel rail. It will corrode the fuel gauge sending unit. I know from running some cruddy fuel in mine. Mine is all fixed now with a few upgrades to it for fuel delivery purpose. Just my 2 cents
Old Jul 10, 2013 | 11:14 PM
47Dodge's Avatar
Are your valves all adjusted properly?
47
Old Jul 13, 2013 | 10:20 AM
47dodge, I had just thought of that this morning and was logging on here to ask that same question. I bought a new 85% cp3 pump and getting installed Monday, I figure I will have them check it while it's In there. I thought I told them to check that when I had the injectors replaced, but sometimes selective hearing comes in to play I have found.
Old Jul 13, 2013 | 10:44 AM
47Dodge's Avatar
Or they did check them and one of them could have come loose. I know when I redid the head on my JD diesel tractor adjusting the valves made all the difference in the way it ran and sounded.
I have seen tork convertors come lose or crack/break from the flex plate on gas engines and create a knock that can come and go depending on load and temperature. Don't know how the diesels are setup as I haven't been into one there. Just a thought. On the old gas stuff you could pop the inspection plate and check/tighten the bolts.
47
SeanB23
Feb 28, 2010 03:09 PM
sallyman1
Jan 27, 2009 10:33 AM
sdaly
Oct 9, 2007 02:43 PM
dodgec68
Jan 2, 2007 08:28 PM
Common
Sep 19, 2006 05:27 PM
