weird clicking noise, then slight change of engine sound
Old Feb 27, 2010 | 06:11 PM
SeanB23's Avatar
So I'm going over my truck, getting ready to haul my stuff up and down the mountains to Texas.
I put new injectors in a little bit back, that definitely helped with the power.
But I noticed the other day, that at idle with the hood open, I can hear a weird clicking noise every now and then, and the engine changes sound just a tiny bit. Not rougher idle or anything, just...different. Then after 30 seconds or a little more, back to normal.
What could this be ?
I have my KSB wired up to an on-off switch on the dash, so it's not that...I don't think anyway.
TIA !
Old Feb 27, 2010 | 06:29 PM
huntinguy's Avatar
Maybe the fan or altinater turning on and off.
Old Feb 27, 2010 | 06:32 PM
A/C or defogger on?
Was this right after a cold start?
Old Feb 27, 2010 | 06:36 PM
SeanB23's Avatar
No, does it all the time. OK, maybe it's the alternator and completely normal ?
Defogger on, AC off.
It's still warm from driving earlier today, I'll go check it right now. Air temp in the upper 50s.
Old Feb 27, 2010 | 06:45 PM
SeanB23's Avatar
OK, I think it's the defogger. Normal then ?
Old Feb 27, 2010 | 06:56 PM
93flatbed's Avatar
Yhea, with defrost the a/c would be cycling on and off.
Old Feb 27, 2010 | 07:02 PM
SeanB23's Avatar
But it's cool out, and the lever is slid all the way over to the "red" side for heat. I don't understand why the A/C would go on and off...
Old Feb 27, 2010 | 07:12 PM
torquefan's Avatar
Most vehicles are wired to run the A/C compressor when any defrost position is selected, regardless of set temperature. The reason is that air conditioning dries the air, as well as cooling it. The defroster is much more effective this way.
Old Feb 28, 2010 | 03:09 PM
The reason it cycles is that the cycling switch is seeing low temperature in the suction line and shutting off the compressor. It cycles less in the summer.
hot_runner58
Jul 13, 2013 10:44 AM
tndiesel
Sep 7, 2011 12:56 AM
sallyman1
Jan 27, 2009 10:33 AM
Common
Sep 19, 2006 05:27 PM
Crabjoe
May 3, 2004 03:43 PM
