shifting from 4 low to 2H
Old Sep 20, 2008 | 07:34 PM
nvr-enuf's Avatar
I have an 2004.5 automatic with a manual lever for the 4 transfer case selections; 4L, N, 2H, 4H.
Issue I have is that I had thought the way to move from 2H to 4L is to put the trans selector in nuetral then change the transfer case from 2H to 4L but this works like crap, gears are moving and grinding occurs. I even tried simply Park but that doesn't work either.
So I read the book and the book says to shift between 3 and 5 mph when going from 4L to 2H or vice versus. Tried this and it did not work, transfer case ended in nuetral and that was it.
Any suggestions? I feel like a more-on that i can not shift the truck from 2 wheel to 4 wheel. I like the 4L for back up heavy loads. Only thing I don't like is that the front end is locked and man, that truck loves to duck walk in 4wd.
THanks
SAS
Old Sep 20, 2008 | 07:41 PM
ripping r's Avatar
I always turn mine off. and have no problems. takes a little longer but grinding.
coparam4x4's Avatar
That's the nature of these x-fer cases. You have to make the shift from 2h to 4L quick and hard. Occasionally I have had to shut the motor down shift it then restart. But as I have done it more and more I have gotten better at making the shift without it grinding.
Old Sep 20, 2008 | 08:53 PM
Pooter's Avatar
Ive had no problems doing it like you tried, rolling, in neutral and switching back to 2hi....
I was rolling 5-10mph when doing it...
Old Sep 20, 2008 | 10:00 PM
RAMRODD's Avatar
I always shift from 4lo to 2hi while moving. I usually go in low 2nd push in the clutch shift the tansmission to neutral then I move the the transfer case to neutral give it half a second then to high range then I shift into 1st gear and let out the clutch at a idel. Never do stop and it works perfect.
When going from low range to Hi I think you might be rushing it make it a 2 step shift and see if it helps.
Old Sep 21, 2008 | 03:07 AM
watson14's Avatar
my 03 grinds them some times but i have gotton alot better making the quick shift
Brendan
Oct 17, 2007 11:12 AM
rockittboy
16
Jan 26, 2007 12:26 PM
ecu68
Dec 6, 2006 12:51 PM
Abbynormal
Apr 13, 2006 02:03 PM
98 Ram 24V
Dec 24, 2005 10:19 AM
