Shifting Problems 4wd Low
Old Dec 5, 2006 | 04:05 PM
ecu68's Avatar
Smile Shifting Problems 4wd Low
Hey Guys
I am so pumped up about DTR web site! I just bought my very 1st Dodge Truck and most importantley my 1st Deisel Truck... I Love It! Never go back to spark plugs!
However I am having a tough time shifting into 4wd low. I have read the owners manuel and have done exactley what it says PLUS I have owned 4wd Jeeps , Broncos, etc. my whole life with manuel transfer cases and have never had this much problem. The truck is brand new with 488 miles on it. When I go from 2wd to neutral to 4wd low the gears grind BAD. So bad I immediately stop trying. I attempted to go back into 2wd. By then my 3-4 mph coast with the transmission in neautral had come to a stop. I tryed to shift into 2wd and it was just as bad. So bad the truck was stuck in neutral and I thought I was going to have to call a tow truck. Finally, I got it into 2wd with a little bit of grinding as it finially shifted into 2wd. I am really gun shy about trying to shift into 4 wd low again, but I will be needing to for towing purposes. I pray no damage was done, but guys Please Help!
Old Dec 5, 2006 | 04:36 PM
cdru's Avatar
If you get stuck in neutral on the transfer case, shut your engine off, trans in neutral, and shift the transfer case, re-start engine. To get it to shift, you must push the shifter "firmly" while stopped or slightly rolling, in neutral gear. Mine shifts into 4 low even if I am stopped. The main thing is be "firm".
Old Dec 5, 2006 | 04:39 PM
dodgezilla04's Avatar
welcome to dtr. fill out your signature so we can see what you are playing with.
Old Dec 5, 2006 | 05:47 PM
ecu68's Avatar
Smile
It is a black 2006 2500 quad cab CTD Big Horn with the automatic. I bought it new with 44 miles on it.
I love the truck.
It is looking to be pretty darn good on fuel too. So far from what the computer beside the windshield visors has me averaging 19-20 mpg which is better than my last truck 2000 1/2 ton Z-71! Yea!
But any advise on the 4wd low is greatful. Like I said I am terrified not to do any damage to it. New trucks like this don't come into my life too often. The trouble I ran into, do you think that is anything to worry about.
Thanks Guys!
Ed
Old Dec 5, 2006 | 06:20 PM
cdru's Avatar
I don't think there anything to worry about. I've had 4x4's for umteen years and I had a little trouble getting used to mine also. Much stiffer than what I was used to. This also my first Dodge.
Old Dec 5, 2006 | 06:38 PM
ecu68's Avatar
Thanks for the words of encouragement! I'm going to play with it a little more and try to get used to it.
Old Dec 5, 2006 | 07:30 PM
Mopardan's Avatar
Like cdru said above. I stop and put tranny in neutral. DON'T stop at neutral on the T case, just 1 swift move straight to 4 low. Never had any problems.
Old Dec 5, 2006 | 07:32 PM
coparam4x4's Avatar
Mine does the same thing. I ended up shutting the truck off shifting into 2wd then restarting. Never had to do this with any of my other 4wd's. Next time I go out I will try the rolling 3-4mph thing that the manual say's to do. I hope I dont have to do the engine shut down thing every time, that would get kinda annoying.
Old Dec 5, 2006 | 07:54 PM
ecu68's Avatar
YEA, I'm right there with you. I bet it is just a trick I need to learn from just getting used to the truck. ........
I hope. Just not comfortable with the way it is meshing of the gears into 4wd low
Old Dec 5, 2006 | 08:03 PM
Tfeore's Avatar
Gotta be FIRM for sure. And don't stop the shift at neutral tcase position...been there done that!!!!
First couple of times were a little scary for me too. Welcome to the best diesel web site this side of Mars...
tom
Old Dec 6, 2006 | 12:51 PM
ecu68's Avatar
Very incouraging! Thanks
By the way I really am pumped up about my new CTD Big Horn! It is awesome and good on fuel!
Ed
wcbcruzer
Sep 5, 2008 08:36 AM
wrangler04
Jul 17, 2007 11:00 PM
VikingDiesel
Competition / Pulls / OffRoad
Dec 29, 2006 07:17 PM
95black2615
Dec 20, 2006 06:37 PM
1320
May 6, 2003 06:30 PM
