?s about wait to start light
Old Aug 28, 2006 | 04:08 PM
Jasco's Avatar
I just bought an 06 yesterday. Is there no wait to start light? on my 2005 it had a light with a little squiggly line on it that would light up and turn off. The 06's do not have anything i don't think. I looked in the owners manual and saw the check engine light will come on and flash after emmissions have been tested or are ready to be tested. Any ideas? Later Jason
Old Aug 28, 2006 | 04:54 PM
jrogers's Avatar
It has to be cold enough to kick on the sensor....when it gets colder you'll see it kick on
Old Aug 28, 2006 | 06:18 PM
06RAMCTD's Avatar
It will need to be down in the lower 50's for the wait to start lamp to illuminate. Unfortunately, you'll have to wait until winter to check it out!
Old Aug 28, 2006 | 07:29 PM
ramcneal's Avatar
You can run a bulb check to see if the wait-to-start light works. Press and hold the trip counter that on the dash, not the over console, while turning the ignition on. The dash will run through a self diagnosis turning on all of the lights and running the dials through their full sweep.
Old Aug 28, 2006 | 08:31 PM
bdo's Avatar
bdo
It is there. Mine comes on most mornings ... 8000ft helps that Takes about 3-4 seconds it seems.
-brad
Old Aug 29, 2006 | 01:05 PM
mule3010's Avatar
Mine has to be in the mid 40's to come on.
Joe
Old Aug 29, 2006 | 01:22 PM
Donut Gestapo's Avatar
Smile
Mine has only come on in the last couple of days with the temps in the very low 60's at night. This morning it stayed on for quite a while. I guess this is the first sign I should put away my shorts and get out my snow boots.
Old Aug 29, 2006 | 03:20 PM
ZacHolley's Avatar
my 03 comes on every time i turn the key over even if its 105 degrees and i have just been driving it all day.
is that normal for 03's??
Old Sep 3, 2006 | 11:55 PM
OR4ster's Avatar
My 04 is the same. Comes on for 2-3 seconds regardless of how hot engine is. When I know the engine is warm, I don't wait for the light--just fire it over.
Old Sep 4, 2006 | 05:50 AM
Smokeman's Avatar
Yes that is normal fon an 03.
mitm
May 20, 2014 12:32 AM
jriggs_18
Jan 11, 2007 04:43 PM
loosendend
Sep 4, 2006 12:01 PM
bfarrell
Nov 30, 2005 03:23 PM
59FORD
Aug 10, 2005 08:09 AM
