Rust on FF5320 Upper lip
I have had the Glacier diesel Filtration kit for a few years now. After every fuel filter change I always simple green the area and rinse. I go for a quick drive to dry it all up and ck for leaks. I notice I sometimes get rust on the upper crevice of the filter. It's always clean on the mating surface of the filter so I am not real worried the rust is going to get into the fuel system. ANyone else experience this? Do I need to be concerned about it?
I just pulled my Cat 1R-0750 off after 30K miles and had zero rust.. But I think the cat uses an alum mounting surface and the Fleetguard is alum.
If its not inside the gasket I wouldn't worry.
The Filter comes with a rubber gasket already attached to it. If your talking about that rubber ring that goes over the Post then YES you have to run it. THats what makes the fuel get filtered. It comes in one side of the filter, passes through the media, then out the other side. If you didn't have that rubber piece then fuel would just go streight through.
Does the FF5320 have one?
Yes the ff5320 comes with the o-ring stem seal. I run the Hastings high efficiency Cat cross over. The number eludes me right now. It is made by Baldwin and does come with a o-ring stem seal. I believe the Cat filter has an o-ring stem seal recessed into the top of the mounting plate.
I will have to look at my next cat. But I know for sure the Baldwin BF7633 doesn't have an o-ring, but due to the specs I just listed I returned all of them.
I had it happen on mine, it wasn't on the inside though. It still bothered me and I changed over to the CAT filter.
Here is a thread with a guy who had very bad water problems and the guts of the filter were rusted.
https://www.dieseltruckresource.com/...highlight=rust
EdmontonCanada
37
Feb 4, 2016 12:02 PM
motrapper
Apr 19, 2008 08:48 PM
checkster
Mar 22, 2008 10:24 AM
Palmetto_kid
Aug 12, 2005 11:37 PM
LatrobeHO
Aug 21, 2003 12:37 AM
