Rough start-up and idle, mileage gone to crap
Old Sep 12, 2013 | 09:53 PM
tmc_31's Avatar
Hey all,
First timer here. I have a 2006 D3500 with 150k on it. This early this week the engine started running rough upon start-up. It would clear up within a few minutes after it warmed up a little. Now it is running rough at idle almost all of the time and the fuel mileage has gotten very bad (as in 10-11 mpg while pulling an empty trailer) Also hearing some funny ticking noises.
It still makes good power though. And seems to run smoothly at highway speed.
Any ideas what may be wrong and how to fix it?
Thanks,
Tim
Old Sep 12, 2013 | 10:39 PM
Spooler's Avatar
Sounds like you are starting to have injector issues.
Old Sep 14, 2013 | 07:46 AM
tmc_31's Avatar
I took the truck over to the local Diesel Injection Service place yesterday. They put a scanner on and told me that I had 3 injectors that were not flowing enough fuel. He said that the injectors needed to be replaced. I asked him if they could be cleaned or rebuilt. He said they just change them. He thought they were about $400 ea.
Has anybody used OK Injector Service (OKINJECTOR.COM)? They are advertising rebuilding these injectors for $70 ea. with a 72 hr turn around.
Tim
Old Sep 14, 2013 | 08:04 AM
XLR8's Avatar
Before you pull the trigger on injector replacement, make sure the fuel pump (and related components) is supplying correct psi...weak pump will cause injectors to act up.
Old Sep 14, 2013 | 09:24 AM
way up north's Avatar
Things are not always what they seem to be. I had a very rough idle in my 07 5.9. I took it to several places and ask for their best guess. Was told it was the injectors.....was told it was the valves needed adjusting badly....did adjust them but no change. Then someone on DTR suggested it could be dual mass flywheel gone bad at 130,000 Kilometres. Spoke to some local mechanics and they agreed. Replaced the flywheel and clutch and she went smooth as silk. Got CENTRIC flywheel and clutch kit all for 700.00 off Amazon and a guy in Texas where we camp the winter installed it all for 300.00
The one thing that might throw this possibility out for you is your bad mileage. I did not experience any change that I noticed.
Good luck.
Old Sep 14, 2013 | 11:52 AM
Spooler's Avatar
DON'T use anything but BOSCH rebuilt injectors. F1 diesel also does a good job. IF, you risk using cheap brand X it will cost you. You will be having constant injector issues, or burn up an engine.
Old Sep 14, 2013 | 10:57 PM
tmc_31's Avatar
Spooler, I tried to look up the F1 Diesel but their website is under construction. Can't tell much about them. The OKINJECTOR guys rebuild your injectors, so if I use them I'll be putting my own injectors back in.
Tim
Old Sep 14, 2013 | 11:31 PM
Spooler's Avatar
Only use trusted folks or you may be in trouble. F1 has venders he uses. I went through Tim at TRE diesel.
http://www.trediesel.com/
Old Sep 14, 2013 | 11:39 PM
Spooler's Avatar
If you don't get ahold of Tim, leave a message with your number. He will get back with you pretty quick.
Old Sep 15, 2013 | 06:46 AM
lane22's Avatar
check wiring to injectors ,wires go thru valve cover gasket
Old Sep 15, 2013 | 10:31 AM
Spooler's Avatar
With that many miles on his injectors, I beat they are done. He had a return flow test done on them anyway and 3 failed.
Old Sep 21, 2013 | 10:09 AM
redneck52's Avatar
Fly Wheel
TMC,
Do you have a standard tranny. I had the same issue like Way Up North. Found that the dual mass was so out of balance that it was causing the injectors to miss fire. Once I got up to high way speeds it seemed to smooth out, but the fuel mileage was real bad.
Old Dec 11, 2013 | 09:15 AM
tmc_31's Avatar
Truck fixed
Ok, I finally took the truck to Abilene Diesel Injection Service in Abilene, Tx. $1500.00 and 3 injectors I am back up and running.
Thanks for your suggestions
Tim
Txbigfoot
Feb 26, 2013 03:24 PM
cbrahs
Nov 1, 2011 11:00 AM
banks twinram
May 18, 2010 08:10 PM
joe22790
Jul 9, 2007 11:04 PM
walt_mink
35
Sep 1, 2005 03:43 PM
