Replacing the fan clutch
Old Apr 24, 2008 | 12:02 PM
ckster's Avatar
I have the A/C blowing warm air when stopped, so I believe the fan clutch is bad. I ordered the new fan clutch and have some questions about installing it. I have the fan clutch removal wrenches, but none of them fit. I know for a fact that the nut is smaller than 36mm, probably around 34.
Does the radiatior have to be removed to get the fan and clutch assembly off? Or do I just remove the 4 nuts from the shroud and pull it from the top/bottom? Is there a special wrench that is used to remove the clutch?
Thanks for the help.
Old Apr 24, 2008 | 12:51 PM
Power Ram 4X4's Avatar
I use a 36mm fan cluch tool and take out the shroud bolts then remove the fan and shroud at the same time from the top.
Old Apr 24, 2008 | 02:20 PM
ckster's Avatar
Thanks for the help, I think the wrench that I got from the autoparts store might be a large 36mm or something, it sure had a lot of slack in it.
FamilyDiesel
Mar 30, 2008 05:53 AM
jrs_dodge_diesel
Sep 28, 2007 11:38 AM
MmmDieselFumes
Sep 27, 2007 06:44 PM
MmmDieselFumes
Sep 27, 2007 03:04 PM
big jimmy
Jul 7, 2006 01:33 PM
