re: trans pan drain kit.
Old Sep 7, 2009 | 12:12 PM
zx14on2's Avatar
i want to put a drain plug in the trans pan. i read someone complained cause the pan wasn't quite flat? has anyone ever welded a nut to the inside of pan, and used a bolt with a rubber washer, like your oil pan? i would think the welded nut, would eliminate any leaking problem if the pan isn't exactly flat. anyone with info regarding this?
Old Sep 7, 2009 | 05:45 PM
1985cucv's Avatar
i just put one on mine and it works great. it doesnt get it all out but once you take the pan off it works fine
Old Sep 7, 2009 | 07:16 PM
zx14on2's Avatar
did you put the drain in a corner or center?
Old Sep 7, 2009 | 07:43 PM
1985cucv's Avatar
i think it is on the front driver side corner fill out your signature it will tell us what truck you got its under user cp on the top of the page
Old Sep 7, 2009 | 08:54 PM
zx14on2's Avatar
sorry. 05 cummins, 48re
Old Sep 7, 2009 | 09:21 PM
pdogg's Avatar
I just put on the one from Geno's ... work great.. no leaks...
Old Sep 8, 2009 | 10:31 AM
zx14on2's Avatar
pdogg- where did you put the drain plug? any pics? I would like to drill a 1/4" hole to drain the fluid before i drop the pan, but i am nervous about the hole being in the wrong spot, incase the drain plug interferes with filter etc.
Old Sep 8, 2009 | 10:37 AM
pdogg's Avatar
I put it in the rear, passenger side of the pan.. no pics, sorry.. if I remember correctly, filter is kind of in the middle... plus you have plenty of clearance I think... this drain plug only has maybe 3/8" protrusion into the pan. What I've heard is you want to stay clear of the valve body..
it's the B&M drain plug...
Old Sep 8, 2009 | 10:45 AM
Dodgezilla's Avatar
I have installed a B&M plug in one of these trucks before and I just ordered one for my current truck. The only thing you really need to be careful of is to put it in a position where there is no obstruction so you can get the pan back on without hitting anything. Works just fine though........
Old Sep 9, 2009 | 03:16 PM
GSW's Avatar
GSW
B&M drain plug kit. I put it on the passenger side. No leaks.
Swarthy Dago
Mar 16, 2009 10:41 AM
SCCSURF
Jan 27, 2009 09:23 PM
klx650a2
Jan 10, 2008 12:08 AM
coparam4x4
Mar 13, 2007 10:28 PM
wooff
May 1, 2003 11:22 AM
