Random Knocking And White Smoke???? Help!!!
Old Oct 8, 2008 | 04:17 PM
Bigsmoke3500's Avatar
Well Over The Past Few Weeks My Truck Would Randomly Start Knocking And Puffing White Smoke? Then If I Shut It Off And Let It Sit For A Minute And Then Start It Back Up It Seems To Run Fine. It Wont Even Throw A Code!! Could It Be Something Shorting Out In My Tst Box? I Checked All Electrical Connections And Everything Seems Fine. Please Help Asap
Thanks,
Matt
Old Oct 8, 2008 | 04:18 PM
Oh And Also There Is No Fuel In The Crank Case Oil Level Is Perfect!?
Old Oct 8, 2008 | 05:49 PM
anyone got answers?
Old Oct 8, 2008 | 06:53 PM
megacabdad's Avatar
Does it happen at any particular time?
Or randomly?
Old Oct 8, 2008 | 07:56 PM
bighornram's Avatar
Unhook the TST.... at least you can eliminate that.
Probably injector trouble though even if no fuel in the crankcase.... at least that is going to be my guess.
Old Oct 8, 2008 | 08:05 PM
sallyman1's Avatar
injector for sure
Old Oct 8, 2008 | 09:22 PM
TriSum's Avatar
Mine was doing that for a month or so. Every so often I would start it and get the white smoke and miss. Then it wouldn't happen for a while, then it stopped. Went about 6-7 weeks and boom !! It's now at Dodge to see what is wrong. I'm pretty sure it's an injector(s). We'll see.
Get it checked.
David
Old Oct 8, 2008 | 10:41 PM
2007 5.9's Avatar
Sounds like a injector hanging open. Go out and get some injector cleaner (Howe's, Seafoam, Power Service), run it at full strength for a tank and see how it runs after.
Pull your fuel filter and see how much crap is stuck to it...maybe a piece of stuff got by it and is hung up in the ball area of the injector.
Old Oct 9, 2008 | 09:20 PM
well i unhooked the TST and it all seems good! SO FAR! i guess ill have to send it back to TST for a rebuild
sleeperman
Mar 8, 2011 02:56 PM
carte89
Oct 6, 2010 11:26 PM
BlackSheep5
Nov 27, 2006 07:52 PM
dhe9
Nov 14, 2003 07:31 AM
