Pac Brake Install Some Pictures and 1 Problem
Heres a link to the pictures and commentary on my install last Sunday. My only problem is that I can't get the seal between the brake and the turbo tight. There is a huge squeal/screech/teapot overboiling/loose powersteering belt noise that comes from the brake when engaged going down a hill. Man is it loud. I was going to buy a new clamp but holy cow they are expensive. I need some ideas on how to ensure the 2 surfaces are tight.
I'm kinda new to the board, and figure I could contribute to the group this way.
Thanks for reading.
I'll try to post the link here. If it doesn't work, I'll post the pictures.
http://picasaweb.google.com/mv.matt1...y=Brg2vM7rTG8#
Thanks for reading.
Maybe try taking the exhaust side off, then loosening and retightening the turbo side.
I remember when I did mine I put the turbo side on first, then I had to push up on the exhaust with a bottle jack to get it to line up with the exhaust brake outlet, so if you tightened the exhaust side first it might be kinda pulling the exhaust brake down a little from the turbo side..?
Great idea. I might have done the exhaust side first. I'll take them off, clean the edges up and reinstall with the turbo side last......tonight. I can't take another day of having the thing installed and not being able to use it!
No luck. Dam thing still whistling at me. I've ordered new clamps for both ends of the brake. Maybe they are worn and need fresh connections. i'm at the end of my rope. May have to take to the dealer to take a stab at it if new clamps don't do the trick. Any chance it could be something else along the line of the backpressure? the Turbo? etc??
Well that sucks, I can't see it being the clamps (bot I'm no expert).
Harold's a member here, he works at Pac Brake, I'll send him the link to this thread, maybe he has an idea.
Good News
I found the problem. The manifold nuts were loose. One nuts to the heat shield actually fell off and must be sitting on the side of the 5 freeway somewhere. The manifold nut was finger loose. I torqued up the nuts, retested the truck and now everything runs like it should! No more whistling!
Thanks for all your help and suggestions.
good job finding problem. Do you have a auto tranny? How do you like it so far? Just finished installing the pac brake in my truck, works great. Finding a few quirks about it though, warmup feature is suppose to activate and hold until 1000rpms, mine doesn't, disengages at about 900. Definitly won't work with manual high idle(1100 start rpm). Don't know how some guys drive with it on all the time though. In city it locks the TC at 50kmh 1200rpms if forget to lockout OD. Read somewhere not to use the brake when in overdrive stresses the overdrive clutches when engaged, does anyone know if this is true? What does everyone else do? Never used one before so just looking for insight. Sorry mvdiesel is this appears to be a hijack, but you were talking of the pac brake.
I think it is going to save me a lot in brakes. I've only used it around town, and in So Cal it doesn't ever get too cold here to use the warmup feature, but I did anyway cause I am happy to have it. It seems to hold rpm at 750 for me. Its really nice how the brake interfaces with the ECM (engine control module) to know when to turn off and on. It sounds like a Mac truck when slowing. Definetly a great investment. I'm taking the family camping in Big Bear this weekend and will see how that brake holds up comind down...
Got as far as compressor, tank, and switch today....just need to do elbow and ecm and I'm done. your pics helped!
the switch instructions threw me off cuz they said white on top, black on bottom. I went with the wiring diagram; black on bottom, white on mid...and confirmed with meter.
I'm glad my pictures helped. I think that is the easiest improvement to make to the truck. I touched my brakes 3 times coming down from 5000' with a #10000 trailer.
If there are other easy performance items I could add I'd love to know about them!
bigbob7777
Dec 15, 2007 06:42 PM
CTD2001
Oct 11, 2007 08:38 PM
staarma
Apr 27, 2006 04:16 PM
