P0483 Code
Old Oct 22, 2003 | 06:34 AM
sawboywv1's Avatar
P0483 Code
Question, I check my default codes evey now and then thru cycling the ignition key. Code P0483 came up last night. No check enging light has appeared. This code is Fan related. Is there a real problem? Because if there was, how would I know about it? Assuming I didn't know the key trick? This code is some kind of hi speed fan relay, however when I checked in the replay box there isn't a fan relay? The only thing on the truck that has changed is I installed a plow last friday, I'm wondering if the wiring of it had something to do with this code? Any suggestions?
Old Oct 22, 2003 | 07:16 AM
sawboywv1's Avatar
Re:P0483 Code
After further digging I think I figured it out. The code means "cooling fan rationaly check malf." The fan did kick in at low speed after installing the blade and the outside temp. was around 50 degrees. That might explain a conflict in the ecu parameters for the fan cycling therefor throwing the code!
Old Oct 22, 2003 | 08:42 AM
jeffteel's Avatar
Re:P0483 Code
Would you mind filling me in on this ignition switch trick for getting codes?
Thanks!
Old Oct 22, 2003 | 08:50 AM
bulabula's Avatar
Re:P0483 Code
From another thread:
[quote author=Sittenbull2 link=board=17;threadid=21030;start=0#msg197469 date=1066271057]
[quote author=bulabula link=board=17;threadid=21030;start=0#msg197374 date=1066256682]
What is the procedure to check for codes on these trucks?
[/quote] Bulabula turn the key to the off then the on postion 3 times, the 3rd time leave it in the on postion it will run through its course if there is any codes it will tell a number like mine did. DO NOT CRANK THE MOTOR on any of the cycles
[/quote]
Old Oct 22, 2003 | 08:55 AM
jeffteel's Avatar
Re:P0483 Code
Thanks!
Old Oct 22, 2003 | 06:44 PM
cem's Avatar
cem
Re:P0483 Code
Ok, I'm stupid here. Where does this code show up? Where can I find a crossreference for the code number to know what it means? ???
Old Oct 22, 2003 | 10:28 PM
jeffteel's Avatar
Re:P0483 Code
I tried it out today. The code would show up in the odometer display, I believe. Mine just said "done"...meaning that there were no codes. As far as the cross reference, do a search on codes here...someone recently posted all of the codes and what they mean. Not sure where they got it, but it looked pretty accurate, and pretty helpful too!
Also, a lot of the major auto parts stores around here can decode them for you if you call them.
Old Oct 24, 2003 | 08:12 AM
JAXFL's Avatar
Re:P0483 Code
under the post "error Codes" today you will find this link...
Check reply #6 on this thread.
https://www.dieseltruckresource.com/...7380#msg197380
I copied and pasted the codes and info to a sheet for keeping.
I think this should be a perminate link on this site forever...
sallyman1
13
May 21, 2008 10:38 PM
kelley15
Dec 13, 2007 06:28 PM
kevinv
Feb 13, 2007 03:03 PM
ZacHolley
Aug 31, 2006 12:27 PM
cquestad
0
Feb 28, 2006 12:49 PM
