engine code p0483
Old Feb 11, 2007 | 08:19 PM
kevinv's Avatar
engine code p0483
I have a 03 ctd ho 24v. the check engine light came on and i pulled the code all it said was cooling fan speed. thats about all i know is that something to be concerned about i have had no trouble with the truck at all runs like a champ. Any thoughts on this? Thanks alot Kevin
Old Feb 11, 2007 | 10:34 PM
orenlasko's Avatar
any answers would be much appreciated
thank you very much
Old Feb 12, 2007 | 07:44 AM
Dan Marino's Avatar
I get this code during cold weather only. It hasnt been an issue. I have talked to a couple different dealers and they both said the same thing. There are many trucks that code this because of some sort problem when the computer doesnt recoginize the temperature correctly and the fan doesnt spin at the proper speed.
I never have a problem with overheating or anything. But I would still call your dealer and ask.
Old Feb 12, 2007 | 08:54 AM
sawboywv1's Avatar
Throw it every time my blade is on!!
Old Feb 12, 2007 | 06:16 PM
reecegr's Avatar
mine also, only when my blade is on.
Old Feb 13, 2007 | 02:56 PM
03sled's Avatar
see mine started to over heat in stop and traffic when towing but onthe high way it was fine. so i pulled a code thats was it po483. you think may be there just starting to go bad?
Old Feb 13, 2007 | 03:03 PM
steelblitzkrieg's Avatar
DTR Detective
Check the fan relays, you should have a spare on your relay box that you can swap it out with. I believe it's your Condenser coil fan, the defrost cycle kicks the AC on intermittently for moisture control. That's why it happens when it's cold out.
If I am wrong someone please chime in, as this was the problem with my 02.
sallyman1
13
May 21, 2008 10:38 PM
kelley15
Dec 13, 2007 06:28 PM
ZacHolley
Aug 31, 2006 12:27 PM
cquestad
0
Feb 28, 2006 12:49 PM
sawboywv1
Oct 24, 2003 08:12 AM
