P0251 & P0480 after fuel injector change
Old Nov 10, 2012 | 05:05 PM
Nicheshok's Avatar
My fuel system and I have been battling each other for the past couple of years. I have changed my cp3, replaced my stock lift pump with a raptor rp-150 and, fan clutch and up until last week 1 fuel injector. The beginning of this week my truck would not start. I had enough and finally just ordered 5 bosch reman injectors and replaced them. The truck started no problem. It has run fine for 3 days now, starting almost immediately after turning the key. I checked my codes yesterday and its throwing p0251 and p0480. From what I can gather people are saying that replacing the FCA would solve the trouble code p0251 and the fan clutch for p0480. I don't know what the problem could be since all of those components have been replaced within the past 1-1/2 years.
Old Nov 10, 2012 | 07:00 PM
BigIron70's Avatar
Cummins Guru
Did you use OEM or aftermarket parts?
Old Nov 10, 2012 | 07:05 PM
Nicheshok's Avatar
The lift pump is a raptor rp150, the injectors are all oem bosch, the fan clutch was purchased from NAPA, the cp3 was oem.
On a side note, I did unplug the FCA when I was troubleshooting the no start to see if that was the problem. Don't know if that could possibly cause the p0251.
Old Nov 12, 2012 | 07:44 AM
jhenson's Avatar
Clear the codes and see which ones return.....we can go from there.
Old Nov 17, 2012 | 12:44 AM
Nicheshok's Avatar
OK, I cleared the codes. Neither the P0251 or the P0480 have reappeared. Now I have P0483 which appears to be fan speed.
Old Nov 17, 2012 | 07:37 AM
jhenson's Avatar
Sounds like the fan clutch is going to be the no start culprit. There's a video on youtube where it's talked about.
Old Nov 17, 2012 | 09:31 AM
Nicheshok's Avatar
Actually the injectors solved my no start issue. I now am getting the fan clutch code which I already replaced just over a year ago. Which is what has me stumped.
Old Nov 17, 2012 | 12:15 PM
Eat Beef's Avatar
From: Alberta Foothills - Power to grow with 6 in a row - XLR8
codes
How do you clear the codes?
Old Nov 17, 2012 | 01:00 PM
Nicheshok's Avatar
Get a code reader or go to an auto parts store and have them clear them for you.
l.a.reisinger
Feb 1, 2014 10:50 AM
quick1sr
Sep 14, 2008 05:38 PM
upjeeper
Jan 1, 2008 06:13 PM
dssimecek
Dec 6, 2006 10:49 AM
SuperGewl
0
Apr 22, 2005 09:10 PM
