Oil Pan Rust Thru
Old Dec 27, 2013 | 06:15 PM
  #46
trik396's Avatar
I did the 2 part JB weld on my pan recently... No problems
Sanded rusted area, cleaned up, applied JB weld over almost entire bottom of pan... Waited about a week then painted with some roll cage high epoxy paint.. Good to go
JB Weld is some tuff stuff.
Old Jan 10, 2014 | 10:03 AM
  #47
frwinks's Avatar
replaced mine a couple of weeks ago. No biggie, remove the plastic black top engine cover and jack that thing up until it hits the firewall, then the pan clears both the crossmember AND pick up tube and bolts are easy to get to. Easy peasy, done in under 2hrs
Old Jan 10, 2014 | 10:24 PM
  #48
barttly's Avatar
How did you jack the engine up? Wondering where is a safe place to put the jack and if there is a place to put a jackstand to hold the engine up when working on the pan?
Old Jan 11, 2014 | 06:28 PM
  #49
frwinks's Avatar
I started off by pulling up by the lift eye on the side of the motor, but I didn't like how it was going up on an angle. I grabbed the stock jack from under the seat, a blocko'wood and jacked it up by the crank pulley. Nice and straight and effortless. If you undo all the pan screws prior to lifting, that motor is only out of the mounts for max 5min.
Old Jan 13, 2014 | 09:19 PM
  #50
bdowney34's Avatar
The pan on my 04.5 is getting bad now. I think I'm going to try the grind and jb weld first. Seems a few guys have had luck with that, better than forking out hundreds for a new pan
Old Jan 8, 2015 | 10:52 AM
  #51
1moomba's Avatar
Originally Posted by chuckydee
Ok, I did it, on my back in the driveway with no hoist. Six hours later because of one engine mount bolt the was rusted. Don't use the truck jack under the crank like I did, its not safe. Lifted the motor up until the heater hose at the back was tight on the top of the fire wall, then the pan slide out with out removing the pick up tube. The only thing I disconnected was the fan shroud and removed the air box,(to get at the shroud bolt).
What year and model? I have 2006 Mega cab 4x4.
Thanks in advance.
04ctd
Apr 21, 2008 03:16 PM
EverydayDiesel
Nov 11, 2007 09:33 AM
tex23455
Jul 25, 2007 02:31 AM
MrKen
Nov 23, 2006 03:19 PM
bostongsx
Sep 25, 2006 11:25 PM
