Oil Filter
Old Apr 19, 2010 | 09:23 AM
  #31
AH64ID's Avatar
The tighter the filter the more soot you catch, but most soot is also sub-micron. And with modern emissions the modern oil is designed to thin soot and keep it from agglomerating, this process makes it VERY hard to filter out. Soot particles by themselves are sub-micron. It takes the agglomeration to catch the soot. Even with my 2um bypass filter I am at 3.9% soot at 22K miles on my oil... The motor makes the soot, and the oil keeps it from doing damage, but beware that it also helps the soot loading increase.
Old Apr 19, 2010 | 09:26 AM
  #32
NavyDood's Avatar
Lost Lake, what filter were you running? You should be fine even going 11,000. Honestly, you might even be surprised at the results... in a good way.
Old Apr 20, 2010 | 07:59 AM
  #33
Tugboat84's Avatar
So I need some help guys. I am the proud new owner of a new to me 06 Mega Cab 3500. I had this site refered to me by a coworker and said you guys know it all, so here I am. I have been reading this forum and trying to research on all the info you guys have posted but frankly I am lost. My truck has had the oil changed everytime at the dealership, every 5,000 miles, according to the carfax. As to what was run in it I have no idea. I recently changed it for a quick trip because it was due and used a fram filter(which now I know was the wrong thing to do) and standard 15-40 rotella(not so sure, right thing to do). I have been thinking of making the switch on all fluids to the amsoil, however the truck has about 67,000 miles on it now and I was told that I am borderline to many miles to use amsoil. Don't understand that but maybe one of you guys do. Anyhow, I am only going to put about 7500 to 10000 miles a year on the truck, with mostly highway driving and towing my fathers 24' fishing boat so what do you guys think I should do? I am really not to interested in trying different brands and using test kits and all that stuff.
Thanks,
TUG
P.S. I currently have 265/70r17 on the truck, am going to put 285/75 on it, on the stock wheels. Leveling kit or no leveling kit?
Old Apr 20, 2010 | 08:47 AM
  #34
AH64ID's Avatar
Welcome!
No issues at all switching at that many miles. Personally I run amsoil in everything I own, I have switched to it at 120K miles before.
As for the leveling kit, pure aesthetics.. So whatever you want.
Old Apr 20, 2010 | 10:12 AM
  #35
rufushusky's Avatar
You should have no problem going to synthetics at that many miles. I go back and forth all the time at three times as many miles. Rotella is a fine oil too, IIRC it is the best selling diesel oil. Don't get too catch up with all the keyboard chemists and oil myths. The only thing I will say is don't use fram, it is the only oil filter cummins has gone out and said not to use.
Old Apr 20, 2010 | 10:17 AM
  #36
Tugboat84's Avatar
Thanks guys yeah I am going to get that Fram off today I believe. Husky IIRC?
Old Apr 20, 2010 | 10:26 AM
  #37
rufushusky's Avatar
IIRC = If I remember correctly.
Old Apr 20, 2010 | 05:14 PM
  #38
Lost Lake's Avatar
I understand your concern going to Amsoil at 67,000 miles....
I mean, is the engine even broken in yet?
It probably is broken in, but barely. Go ahead and use the Amsoil and run another 90,000 miles until you have to adjust the valves, then you can go another 300,000 miles or so before you should think about doing a top-end rebuild.
Old Apr 20, 2010 | 08:09 PM
  #39
Tugboat84's Avatar
Lost Lake,
What do you run? Oil and Filter.
Tug
Old Apr 20, 2010 | 08:46 PM
  #40
hector's Avatar
my truck had 85k on it when I bought. I changed to amsoil & fleetguard. May try donaldson elf 7349 next . Found them online for the same as fleetguard
Old Apr 21, 2010 | 04:44 PM
  #41
c-bass's Avatar
hahaha
what an appropriate term
Old Apr 21, 2010 | 05:43 PM
  #42
Lost Lake's Avatar
Lost Lake,
Tug
I use the Fleetguard Stratapore and haven't found a favorite oil yet. I just had synthetic 5W-40 in for winter and changed that out 10 days ago with DelVac 15-40. I bought the DelVac for $6 a gallon. I've put 3000 miles on since the change, so I'll be due again in a couple weeks. I'd like to try the Valvoline Premium Blue and see what kind of UOA reports I get.
Old Apr 22, 2010 | 01:38 PM
  #43
bonus's Avatar
pls post UOA if you do it. also, the Delvac has been about the best CJ oil going.
Old Apr 22, 2010 | 11:28 PM
  #44
Dieseljunkie's Avatar
Originally Posted by AH64ID
You early HPCR guys are lucky.. I can only squeak to 25K miles on AME with a bypass.
I run AME, with the EA080 filter, and no bypass on my 04.5 HPCR... I ran this last batch for 30k miles, then sent it in for analysis, it still came back as "good" to use for longer, but I changed it anyway, because I had already bought the oil, and was coming up on the one year mark anyway.. Amsoil works for me, so I use it. Some people don't like it, or refuse to use it, and that's fine. Use what works for you, and I will use what works for me
Scott
Subliminal
Jun 16, 2011 03:26 PM
vegashd
Jul 15, 2007 12:24 PM
danc46
Jan 6, 2007 05:24 PM
roc155
23
Mar 9, 2006 06:44 AM
turbo59pwr
Jul 9, 2003 04:24 PM
