need advice for long haul with cattle
Old Nov 1, 2005 | 07:59 AM
motrapper's Avatar
new truck in sig only 2987 miles leaving with empty 20 ft gooseneck and returning with 10 first calf hefiers any tips or extra parts to take to make a smooth trip from south MO to central NE and back about 1600 round trip
thanks
Old Nov 1, 2005 | 08:14 AM
bigblock2stroke's Avatar
thanks
extra belt? Do you run and exhaust brake? Extra fuel filter in case you get bad fuel?
I assume you've done trailer checks/maintenance and have spare tire/wheel and means to change. Make sure tires are inflated as close to max as your acceptable ride quality will allow.
If you haven't done and oil/oil filter change since new, I'd do one just to get the "wear metals" out. I also did my rear diff to get any wear metal out if it.
Old Nov 1, 2005 | 08:46 AM
IA_James's Avatar
Ditto on the oil and diff changes. I did the motor oil on principle at 1500 miles, and the diff at 10k. Wish I had done the diff sooner, it had a lot of silver in it.
Old Nov 1, 2005 | 09:10 AM
wap's Avatar
wap
IA James could you tell me how much oil to put in front and rear diffs.
I would also like to see what yall recomend on the rear end wight, I do haul a good bit anything from a 16' to 24' stock trailors, and flatbeads.
Also what type and brand of oil to run in the diffs.
Thanks
Old Nov 1, 2005 | 09:52 AM
jd4030's Avatar
Thanks
I use Mobil 1 75-90, this or 75-140 would be fine. Be sure & use synthetic, it lasts much longer & changing diffs. is a messy job. My rear axle takes 3 1/2 quarts, front 2 1/2, but I have the Dana's. Not sure about the newer ones. I would also do an oil change before you head out. This will be a good break in trip.
Old Nov 1, 2005 | 10:58 AM
bulabula's Avatar
I'd buy 4 quarts for the rear and 3 quarts for the front diff.
Old Nov 1, 2005 | 12:57 PM
wap's Avatar
wap
Thanks fellas
Old Nov 1, 2005 | 06:09 PM
Geico266's Avatar
Did anyone mention hay, a scoop shovel, or water? He said he was hauling cattle and I don't think they are potty trained.
I'm in Lincoln, NE if you need help or a place to run the cattle for the night.
Old Nov 1, 2005 | 07:19 PM
hammerjammer's Avatar
the truck is new with 2,900 miles. Don'r waste your money changing anything.Drive it and break it in. Then follow the B schedule in the owners manual.
Old Nov 1, 2005 | 08:45 PM
rich's Avatar
when i used to haul livestock that far we did feed some hay but diidnt stop for very long maybe 3 or 4 hrs sleep if you can get a driving partner it would be better. Just check the fluids and you'll be fine i run about 4 to 5k a month and change my oil about every 15k and the trans about 50k and the diffs about 25k. yours is to ne w to woory about just keep onj eye on it and then change after trip just my .02
Old Nov 1, 2005 | 09:53 PM
StrokeThisCTD's Avatar
Um if it were me i would hook the trailer up and go, dont forget a CD or two if you dont have satellite radio. I guess i just trust my truck enough to make a long trip without any problems
Old Nov 2, 2005 | 12:29 PM
Hounddog's Avatar
That new of a truck.JUST DRIVE it.Service asnormal for about 100k.Then carry spare stuff.
Old Nov 9, 2005 | 04:36 PM
motrapper's Avatar
at 2300 i did swiich to mobile 1 truck and suv oil 5w 40w pulled hard on the 2nd thousand now does walmart have the rear diff. fluid 75-140w for the front and rear syn
thanks guys and i might look up the guy in lincoln NE when i jump on i 80 from nebraska city
texashaybaler
Big Rigs
Mar 7, 2015 10:39 AM
Sean S
Nov 20, 2003 10:23 PM
Hired Gun
Dec 7, 2002 01:08 PM
TXBobcat
Nov 22, 2002 09:01 AM
