my tranny sux
Old Aug 15, 2012 | 11:37 PM
dodgebob03's Avatar
my tranny sux
03 2500 2wd with 5spd auto and it sux. Shifts from 3rd to OD almost skipping fourth completely and when pulling kick OD off and goes straight to 3rd and RPM's shoot to 2500 and lose the TORQUE that I bought the diesel for!! Would love to convert to 6 spd manual but what are my options for the auto? Is there a six speed auto for the 03? I love the truck and the engine but.......TRANNY SUX!
Old Aug 16, 2012 | 01:07 AM
Fiftygrit's Avatar
I think your 03 is the same as my 06, they only have a 4 speed auto, the 47re and the 48re are the same for the amount of gears,if I push my shift button twice it goes to overdrive off, which is 3rd, I just leave mine in (tow-haul) mode,"towing" not sure if yours has this.
Old Aug 16, 2012 | 01:09 AM
dodgebob03's Avatar
No the 03 only has OD OFF. What is the diff between tow/haul and OD OFF??
Old Aug 16, 2012 | 11:20 AM
steelblitzkrieg's Avatar
DTR Detective
Changes shift points, firmer shifts, and I believe TC lock-up in 2nd, 3rd, and 4th.
Also if I am going 60mph down a long grade and lightly on the brakes for at least 5 consecutive seconds it will downshift and lock the TC acting sort of like and engine brake.
Old Aug 16, 2012 | 12:06 PM
Spooler's Avatar
Upgrade your tranny. Not sure what mods you have done. Update your signature.
Old Aug 16, 2012 | 12:07 PM
Spooler's Avatar
No tow/haul in the 03-04.5 trucks. Only OD lockout.
Old Aug 17, 2012 | 02:06 AM
dodgebob03's Avatar
OK you prbly figured out I'm a diesel beginner. What mods do I need for my truck to pull 12,000 pound fifth wheel and boat? Not even sure what tranny I have yet. 47re or 48re?
Old Aug 17, 2012 | 06:27 AM
j-fox's Avatar
Dodge does NOT have a 5 speed auto for the diesel!!!!!
There are many who think there is.
It is a 4 speed auto.
The way they want to use lock up makes people think it is a 5 speed.
Here is how it goes.
1st to 2nd, then
2nd to 3rd, then
3rd to lock up, then
depending on ground speed, it will shift to 4th (OD ) and can do it with the converter locked or unlocked.
This is what you feel and think it is skipping a gear.
Old Aug 17, 2012 | 06:31 AM
j-fox's Avatar
Get the vin number from your truck. The 6th character will be either a ' C ', or a '6'.
C is the 48 re
6 is the 47re.
No one can answer your question until we know more about your truck.
Fill out the profile and signature. It is in your control panel.
At a minimum, your auto will need a transgo shift kit. Depending on the condition of it, you may need a rebuild along with it.
Old Aug 17, 2012 | 09:50 AM
DTR Detective
47RE
A renamed second-generation A618. A heavy-duty A727 with overdrive and electronic control.
Applications:
1996-2002 Dodge Ram 2500/3500 Diesel/V10
48RE
The 48RE is an electronically-governed, four-speed heavy-duty overdrive automatic transmission, stronger than its predecessor, the 47-series.
Gear ratios:
1 2 3 4 R
2.45 1.45 1.00 0.69 2.21
Applications:
2003-2004 Dodge Ram 2500/3500 ISB Diesel
2003-2004 Dodge Ram 2500/3500 HO ISB Diesel
2004-2007 Dodge Ram 2500/3500 600/610 Diesel
2004-2006 Dodge Ram SRT-10
Old Aug 18, 2012 | 02:30 AM
dodgebob03's Avatar
Ok that makes sense. So when I am feeling the "bucking" when I thought I was in fourth, I was actually in 3rd with TC locked? OK now why the bucking? Thought tranny was slipping there too.
I forgot to mention the bucking only occurs onder load while towing my fifth wheel and boat. About 12,000 pounds.
Old Aug 18, 2012 | 02:31 AM
dodgebob03's Avatar
It is a 47re
Old Aug 18, 2012 | 02:35 AM
dodgebob03's Avatar
Filled out my sig. why is it only showing sometimes?
Old Aug 18, 2012 | 02:38 AM
dodgebob03's Avatar
BTW this site is awsome! Learning alot from you guys! I appreciate the help and the patience.
Old Aug 18, 2012 | 11:40 AM
DTR Detective
Sig only shows in your initial post in the thread. Why it skipped your first post and shows it on your second, I don't know.
PencilPauley
Introductions / New People
Jan 14, 2012 01:42 PM
S.TX.MEGA
13
Jul 7, 2011 07:14 PM
Black Dog
Dec 3, 2009 08:18 PM
simco6
32
Aug 3, 2006 06:19 AM
Ph4tty
Jun 20, 2006 06:19 PM
