My '06 is dead.
My '06 is dead.
Well, this morning I went to start my truck (almost 41K on the odo.), and it fired once, then died. I tried again, and it just cranked, but wouldn't fire at all. tried a couple more times; nothing. I bought it used back in September, and it has never done this before. However, every 1 in 5 times, it would take 2 cranks to start it, ever since I bought it. Sounds like progressive failure to me. The truck was built Dec. 7th of 2005. Any ideas? Injection pump? Lift Pump? Seriously clogged fuel filter? (
yeah right). What were some of the common ailments of the '06 fuel system? I already miss driving my truck!
I had the truck scanned by a master Cummins mechanic at a Dodge dealer, whom I'm friends with. truck shows no evidence of modification whatsoever. I changed the fuel filter (Napa Gold) back in early December. It probably has less than 4K miles on it.
Have you tried to undo one of the fuel lines to a injector to see if its getting fuel? Had a similiar problem, killed the truck then tried to crank and would not fire just would keep cranking over, turned out to be the ac compressor was locked up, when I removed the belt fired right up.
sounds like a bad injector that will not allow the system to build rail presure or a bad relief valve. try to unplug the fca and crank it over to see if it starts. Or you can unplug the grid heaters and give a small shot of ether into the intake.
That's a transmission code. It doesn't mean much really if it hasn't lit up recently... Like maybe someone over worked the converter back before you bought it.
I'd try cranking it a few more times and maybe connect a jumper box to the battery if it doesn't crank and see if it throws another code.
I know on my 07 it would do weird start up stuff like crank over fire for a sec and then continue to crank to only throw a check engine light and I'd have to try to start it twice.
It was a bad battery or possibly a bad connection on the battery (I bought new batteries anyway). After the new batteries I deleted the code and everything is back to normal. The code was P2509 though.
Anyway, I'd check connections, cables and batteries first before diving into the fuel system. The fuel system is covered under warranty but it would suck paying for a tow and diagnostics if it's just something simple you can spend an hour figuring out.
600 Megawatts
Mar 26, 2008 07:09 PM
Jvenne86
17
Mar 20, 2007 08:27 PM
