Mobile 1 atf does it meet specs for G56 and transfer case
Old Apr 15, 2008 | 09:24 AM
motrapper's Avatar
it says mecron and mercon 5 and allision 5 and how much does each one hold
thanks
Old Apr 15, 2008 | 10:02 AM
Roperteacher's Avatar
Your G 56 and Transfer case require ATF+4. If it meets that spec your good to go. I drive a 4x2 so not sure on the transfercase amount but you put 6 quarts in the G-56..
Old Apr 15, 2008 | 10:49 AM
DBLR's Avatar
motrapper,
You are correct as the last time I looked at Mobil 1 ATF it was not made for use in Dodge transmissions that required ATF+4 fluid. The only ones I've seen on the store shelf who have approved ATF+4 fluid are Mopar, Valvoline and Wally World brand. IIRC in the full synthetic world only Redline and Amsoil have a ATF+4 fluid.
Old Apr 15, 2008 | 10:50 AM
D45's Avatar
D45
Mobil 1 AFT will screw up your tcase!
A few years ago, I put some in my old '93 Dakota 4x4's tcase and it would pop out of 4HI.
I then flushed it out and replaced it with Amsoil ATF and it shifted flawlessly.
Still working great to this day with 180,000+ miles on the stock tcase.
Old Apr 16, 2008 | 01:03 AM
XLR8R's Avatar
Use plenty of +4 or else...
https://www.dieseltruckresource.com/...3&d=1207871235
Old Apr 16, 2008 | 12:21 PM
mrblond's Avatar
Originally Posted by XLR8R
What am i suppose to see in the pic? What happened?
And I called Mobil Oil a few months ago and they say a NO to using the M1 atf in the G56 as it does not meets all requirements.
Old Apr 16, 2008 | 09:42 PM
XLR8R's Avatar
It's the guts out of a G56 that was underfilled for most of 80K miles...
Old Apr 17, 2008 | 12:36 AM
PourinDiesel's Avatar
Any Chrysler rated ATF fluid should be fine. The additive package that designates +4 is mainly for the Automatic transmission.
BearKiller
Nov 20, 2008 08:59 AM
24seven
Mar 12, 2007 12:51 PM
low c1500
Jun 28, 2005 02:35 AM
perk
Feb 29, 2004 12:20 PM
