My transfer case is leaking ATF
Old Jun 25, 2005 | 08:13 PM
low c1500's Avatar
My transfer case is leaking ATF from the seal between the front and back casings. In my reapair manual it says that there is just a "sealant beed" and not a gasket there. Does any know if the back half of the transfer case and be easily removed (once the tail housing is removed). Then I could just apply some new sealant.
I just don't want to crack the case open and half parts falling out.
Old Jun 25, 2005 | 08:38 PM
JAF's Avatar
JAF
I don't know now mechanically incilned you are but I can completely rebuild a t/case in about 30 minutes. All the pieces pretty much stay in one side.
Old Jun 25, 2005 | 10:27 PM
low c1500's Avatar
Any suggestions on what sealant to use? Maybe RTV silicone?
Old Jun 26, 2005 | 01:52 PM
Barry Smith's Avatar
I've got my transfercase laying on my tail gate right now. You don't want to pull it apart in the truck. As soon as you break it apart there are going to be a few pieces hit you in the head!
I was having a noise in 2WD so I pulled it out and apart and there are 3 broken snap rings! I'm glad I pulled it when I did. The only thing between the halves is RTV and that is all that's between the transmission and the transfer.
Old Jun 27, 2005 | 04:56 PM
low c1500's Avatar
Well I did pull it apart in the truck. The only parts that came falling out were the sping and cup for the shift fork. I use blue RTV silicone, and after one day it doens't seem to leak.
Old Jun 28, 2005 | 02:35 AM
I'm glad you didn't have any trouble with it! At least you were watching for falling parts!
thebestofindica
Jun 18, 2009 12:11 AM
motrapper
Apr 17, 2008 12:36 AM
vrj
Oct 20, 2005 05:47 PM
perk
Feb 29, 2004 12:20 PM
