ATF for the Transfer Case ???'s
Old Feb 27, 2004 | 08:58 AM
perk's Avatar
I am replacing the rear output seal in the t-case this weekend, and am going to change the fluid while I am at it. I know that the t-case takes ATF, but do I use a dexron III or some other type of ATF. I do plan on using synthetic, if I can find it locally.
Old Feb 27, 2004 | 11:05 AM
dsldan's Avatar
I used Mobil 1 syn dexron type... advance auto or auto zone should have in stock.....
Old Feb 27, 2004 | 12:57 PM
perk's Avatar
I found redline available locally, but the place says not to use it in that application. The dealership said to just use regular atf, but any dexron III or IV.
Old Feb 27, 2004 | 02:56 PM
HOHN's Avatar
Redline D4
Mob 1 is good if you can't wait for the RL to come in the mail.
Justin
Old Feb 29, 2004 | 12:20 PM
perk's Avatar
I made a mistake with the redline, the place that said not to use the redline only had the MTL which is for manual transmissions, which should not be used in the trasfer case. Redline's ATF should be fine in the t-case. I put in Mobil 1 syn because that was all I could find locally.
thebestofindica
Jun 18, 2009 12:11 AM
motrapper
Apr 17, 2008 12:36 AM
vrj
Oct 20, 2005 05:47 PM
low c1500
Jun 28, 2005 02:35 AM
