ATF drip near transfer case
I have replaced the tailshaft seal and siliconed the soft plug at slip yoke, so these are ruled out. I can't tell where the leak is because it throws ATF on the underbody and then drips in various places from there. Any thoughts? I just bought this 03; how does a guy find out if its out of warranty? Would this be covered under 100,000 mile warranty? Should I go ahead and replace slip yoke and u-joint while I'm at it? I hate to throw money at it just because.
Thanks a lot
Thanks a lot
Well, I think I understand what your saying. Just a guees, but its is usually an 06 problem, but between the Turbo and the Block is a steel line and it has a red rubber hose inline of it. The clamps usaully loosen up a little and it drips coolant down the back of the block and off your bell housingish area. Some report it comming off there transfer case and splattering all the way back to the rear. It looks just like tranny fluid too. Probably not it because you just made some repairs in the general are, but something to look at. I may be way off too.
BearKiller
Jul 11, 2022 02:43 PM
dslpwr81
28
Jan 26, 2009 09:08 PM
b4wheeler
Apr 18, 2007 03:54 PM
