low speed vibration
Old Aug 7, 2006 | 11:36 AM
telephonman's Avatar
low speed vibration
O.K. here's whats going on with my '05. Yesterday I was driving along, and as I came to my turn off, I was slowing to turn, then when the truck got to about 10mph it started shaking bad. I pulled over to the side and got out to check it out. thought that I might have a rear inside tire flat, nothing looked out of the ordinary. I drove off, very bad vibration at 5-10 mph, smooth as always when over 20mph, any thoughts before I take it to the dealer. I am going to sit it up on jack stands this evening when I get home, and let it idle in 1st or 2nd gear to see if I can see anything doing something its no supposed to.
Old Aug 8, 2006 | 03:24 PM
hparfitt's Avatar
Had a similar problem.
My truck is a 04.5 6 spd. It has 40K miles on it. My problem was, I'll call it seized u-joints. There was no rotational play in the drive shaft. I dropped the driveshaft and the rear joint, the axis on the shaft was seized. Upon disassemply I found no grease in the rear joint. I replaced my u-joint with greasable precision #351's. Like $40 a piece. I had a 1 piece shaft no carrier.
Old Aug 8, 2006 | 04:25 PM
MedicShawn's Avatar
Sounds like mine same deal with 50k. I replaced all 3 while I had the shaft out. Fixed my problem.
Old Aug 9, 2006 | 12:34 AM
jwsmith97's Avatar
Hate to "me too", but had the same problem at 58K on 2003. Warranty covered replacing U-Joints.
Old Aug 9, 2006 | 06:54 AM
This truck only has 18K, I got under the truck, the carrier bearing or bushing it looks like to me a very cheap, weak design, has alot of up and down play in it, dont know if it should have any play in it or not, I guess to the dealer I go.
Old Aug 9, 2006 | 08:14 PM
drew03's Avatar
had same problem with mine as well as the back of the transfer case was leaking. i thought i was going to have to hit the service manager with a board because he was certain that i had warped rotors. They replaced the yoke and seal which is supposed to fix my leak. I just got it done today so i will have to wait and see if the leak is gone. They said by back u-joint was binding so they replaced it as well. Everything is good now, all was covered under 7-70 powertrain warranty. I was supprised they did not give me any problems about my k&n or my straight pipe, but i took the edge off before i went
Old Aug 10, 2006 | 11:33 AM
I called the dealer, said they cant get me in till tuesday, ,I've all ready taken the xzt off for the dealer trip.
Old May 22, 2007 | 03:22 PM
ko4amd's Avatar
Thanks guys, you just described my problem to a T. I thought it was tires but they are good. 51K.
Old May 22, 2007 | 04:36 PM
Nate-03 D's Avatar
Do the 03 trucks have greaseable driveshatfs like the newer models? I know they require a specific kind of grease fitting to get to them.
Old May 22, 2007 | 05:05 PM
vzdude's Avatar
DTR's 'Go to Guy'
Most manual trans. drivers will see a lower mileage interval for replacements on the u-joints due to the added stress ( usually ) put on them when shifting. Autos seem to be a little smoother on the shift, with less stress.
Old May 23, 2007 | 08:38 AM
PADZZ's Avatar
Same thing here. It goes away when towing my 5th wheel. I'll try and get it in next week. 36,xxx miles.
Old May 23, 2007 | 09:44 AM
jeff-kc9ftp's Avatar
great timing guys
I just had tires rotated last week, thought it might be related to that. Didn't make sense that it was only @ 5-10 mph, though. Gotta go out of town next week, no time for the dealer to check it out. guess i'll be doing u-joints this weekend
jeff.
Old May 24, 2007 | 04:56 PM
ko4amd's Avatar
Anyone know the part number for the carrier bearing? Should I change it while I do the U joints? I can not find any carrier bearings and need this fixed early next week to go Camping. I have my priorities. LOL.
Thanks
rjm022
Jul 13, 2013 07:23 AM
RobG
Jan 15, 2012 09:04 PM
Haney
Oct 31, 2010 05:07 PM
Rednecktastic
17
Jul 10, 2009 07:46 AM
tool
Dec 5, 2008 10:16 AM
