Low-Speed Massive Vibration Problem
Old Jan 11, 2012 | 07:49 PM
RobG's Avatar
My truck has developed a problem in the last week. It started out only being around at 6-7 mph (indicated) in 1st gear (6sp G56), but as of today it's now around at higher speeds, but I haven't dared go above 40 mph while out trying to figure out the cause.
It's definitely a driveline vibe. Push the clutch in and the problem remains. Tranny in neutral and coasting and problem remains. It gets really bad when slowing through the 6-7 mph range.. as in seismically bad.
I feel it a bit in the steering when turning, but the best way to describe it is as if something below the truck is attempting to shake the truck apart.
My two best guesses are transmission mount and/or the U-joint at the transfer case.
I was under the truck earlier when it was daylight and the trans mount looks okay, but that doesn't really mean anything. I didn't think of the U-joint at that time so I didn't look there. I was just looking for leaks or anything out of place, and all was fine.
What do you think? Also if it IS a U-joint, can somebody recommend an SF Bay Area (south bay preferably) driveline shop to do the job?
Thanks!
Rob
Old Jan 11, 2012 | 08:35 PM
PoorMansCat's Avatar
it definitely sounds like a ujoint issue... Do not drive it up at highway speeds, excessive vibration/locked up u-joints can tear up the transmission/transfer case.
Old Jan 11, 2012 | 09:51 PM
rockcrawler304's Avatar
Any noise when stopped? It could also be the flywheel coming apart.
Old Jan 12, 2012 | 06:24 AM
smartin1's Avatar
Also check the carrier bearing. Had mine go bad. Also replaced ALL the u joints. Can't really see if one is dry and binding inside. What is the mileage?
Old Jan 12, 2012 | 01:02 PM
RobG's Avatar
Had it towed to a shop today... South Bay Driveline... had great reviews on Yelp for being a straight-shooter with fair prices.
All the U-joints in the driveshaft are shot along with the center support bearing. They said the spline didn't have any grease in it which is what caused it. What would cause the spline to have no grease?? Sure wish it was still under warranty. 86k miles but being an 05, warranty's been out for over a year.
$607 to repair. They'll have it done in a couple of hours.
Rob
Old Jan 12, 2012 | 07:14 PM
RobG's Avatar
Got it back. WOW what a difference. I guess this problem has been building for some time. The thing is actually SMOOTH now! It's like a new truck.
The issue was the spline where the two halves of the driveshaft fit together. They don't put enough grease in from the factory, so unless you know to grease it (and you have to disassemble it to grease it), you'd never know until the thing failed like it did for me.
The lack of grease caused the thing to lock up. They salvaged the splines but said it'll have to be replaced in another 20-30k miles.
So, if you have more than, say, 80k on your truck, pull the rear section of your driveshaft and regrease it. He did say to not use too much grease because it would blow the plug and get everything contaminated, so be careful.
Rob
Old Jan 12, 2012 | 10:16 PM
Thanks for the update and info!
I have just turned 100k. I guess I know what I will be doing very soon!!
Old Jan 13, 2012 | 02:08 PM
.boB's Avatar
Rob
This usually means a suspension problem, and not a drive line problem. Drive line problems are usually related to engine rpm and/or load.
Get the truck up in the air, and check all your steering and suspension components. Since it's more pronoucned whill turning, that usually means front end - but not always. If the front checks out OK, move to the rear.
Old Jan 13, 2012 | 03:16 PM
Lost Lake's Avatar
Bob, he solved the problem already, and you are wrong.
Wow that kind of sucks huh? LOL! Just kidding!
Old Jan 14, 2012 | 02:46 PM
.boB's Avatar
Nope, doesn't suck. I'm wrong sometimes. That's why I use the word, "usually". And, that's why I read boards like this one.
Bad carrier bearings and U-joints usually show up under a load.
Old Jan 15, 2012 | 09:04 PM
Lost Lake's Avatar
Yes, I agree, just funny how you posted after he had solved the issue and had the wrong advice.
I get a pronounced take-off shutter, probably worse than it has been, and I have recently installed a 2.5" front lift, have air bags lifting the rear, and a new trans.
Goerend said they questioned the integrity of my motor mounts.... But I think I may have a carrier bearing going.
I should just get the one piece shaft.
rjm022
Jul 13, 2013 07:23 AM
Haney
Oct 31, 2010 05:07 PM
Rednecktastic
17
Jul 10, 2009 07:46 AM
tool
Dec 5, 2008 10:16 AM
telephonman
May 24, 2007 04:56 PM
