Low Boost code
Old Oct 22, 2006 | 05:11 PM
MOJO1's Avatar
Low Boost code
My truck keeps throwing a low boost code. Truck is basically stock just a TST box. It was doing it before i put the TST on. I could use some help here. THANKS.
Old Oct 24, 2006 | 06:20 AM
MOJO1's Avatar
Unhappy
Come on guys help me out here. Throw me a few coments im lost on this one.
Old Oct 24, 2006 | 06:29 AM
one4speed's Avatar
What is the code number? I don't think PO237 is one of the common CEL codes with the 2006. You might want to remove the box, set the code and take it to the dealer.
one4
Old Oct 24, 2006 | 09:25 AM
Sloverado's Avatar
The low boost on my 05 is po299. It seems to only happen when i get the truck some fuel when it isn't totally warmed up yet with the TST on.
Old Oct 24, 2006 | 02:30 PM
bigwheels94's Avatar
Have you checked your MAP sensor?It may be dirty,damaged,etc.Also check your turbo boots to the aftercooler,& make sure they are all tight,& have no holes in them.How is your air filter?Otherwise I agree with the last post.Remove the box,& bring it in.May be a glitch.
Old Oct 24, 2006 | 02:40 PM
dodgezilla04's Avatar
check the connector at the turbo also. there is a flat black connector behind the oil filter. the map is on top of the intake manifold.
Old Oct 25, 2006 | 10:11 AM
MOJO1's Avatar
Thanks guys for the help i checked all the connectors. The turbo connector looked pluged in (BUT WAS NOT) pluged it back in works fine now.called TST said there was some isues with these trucks throwing codes. trying to fix the problem he said.
Old Oct 25, 2006 | 11:18 AM
whoo hoo. i actually got something right for a change. glad you got your issue resolved.
jmccart
Apr 5, 2011 06:13 PM
jmlcolorado
May 19, 2010 10:30 PM
Moobesor
Feb 23, 2008 09:57 AM
daveg
13
Feb 1, 2008 11:05 PM
