Light Ticking/Pinging noise when turning
Old Aug 31, 2010 | 04:30 PM
Sumdumgi83's Avatar
Hi folks,
I have a 04 2500 4x4 and had the U-joints replaced in the front axles with high quality parts by a reputable shop who specializes in 4x4. The grinding stopped but I still hear a ticking noise in the front somewhere. It sounds almost like the cap on my wheel is loose and making this pinging sound. Especially turning or if in deep ruts on a dirt road and the tires are flexing. I took it back to the shop and they lifted it up. Checked the u-joints and they were in great shape. They grabbed the wheel and tire and started rocking it. The hub assemble had a small amount of play in it on the driver side. My question is do you think this is whats causing the noise and what risk do I run in driving it for a while? Its not my daily driver so it wont get more than 500mi on it in a month. Also the replacement looks easy but what brand and where should I buy the replacement.
Thanks in advance for any advice you can lend.
Old Aug 31, 2010 | 06:38 PM
Jeff in TD's Avatar
They are sure the slop is in the hub/bearing?
If so I wouldn't run it, for fear it would seize or come apart.
Old Aug 31, 2010 | 09:20 PM
Tacomaman87's Avatar
id run it most you will do is wear out your brake pads warp your rotor and put some uneven wear on your tire. it will start making lots of noise before it comes apart.
Old Sep 1, 2010 | 08:11 PM
Sumdumgi83's Avatar
What brand do you recommend to replace it with? I think I will wait a while but will replace as soon as the funds build up again...any favorite sellers of this part?
Old Sep 1, 2010 | 08:29 PM
PoorMansCat's Avatar
somebody needs to make a retro-fit kit that uses rebuildable, quality bearings.. Short of that, put a Dyna Trac free spin kit on it.. I think it uses Timken bearings..
Old Sep 1, 2010 | 10:16 PM
spdnby's Avatar
typical cost of the dyna trac to free spin the front....me and my budddy discussed this last nite.....he said about 2500 bucks....was he in the ballpark?
Old Sep 2, 2010 | 06:41 AM
spdnby's Avatar
please dont respond ...i apologize for changing the subject of your posts...
Old Sep 2, 2010 | 11:49 AM
Jeff in TD's Avatar
I don't really know much about what brands there are, but since no one has made a recommendation...
A buddy of mine lost a front wheel bearing, and I think he bought whatever brand Napa was selling. It seems to be fine and was reasonably priced.
Old Sep 3, 2010 | 06:44 PM
Sumdumgi83's Avatar
Thanks guys. I asked the shop that did the front axle u joints and they said BCA...guess thats what I will go with once I decide to do it. Looks like an easy job.
rocksride
39
Feb 21, 2014 11:07 AM
klx650a2
Oct 14, 2010 09:18 PM
1985cucv
Apr 11, 2010 10:42 AM
Diesel_Dan
Jan 26, 2007 01:06 PM
pipercoal
May 31, 2004 01:37 PM
