Lift Pump Replacement Recommendations
Old Aug 12, 2007 | 08:59 AM
dezeldog's Avatar
Glacier here as well and it is a very easy install and great people to work with. About 15k worry free miles.
Jim
Old Aug 12, 2007 | 09:44 AM
3500eh's Avatar
i am in a bit of a fix here with my stock lp. mine is severly on its way out and i cannot get a walbro as soon as i need it( have to order it from the states to canada and will likely sit at customs for a bit) .
only lp i can find is another one that mounts behind fuel filter cannister. should i bother to order a walbro also?
Old Aug 12, 2007 | 09:50 AM
3500eh's Avatar
stupid question here. when does lp actually lift the fuel? when starting, or all the time?
Old Aug 12, 2007 | 10:14 AM
cameroneod's Avatar
As soon as you turn the key it starts pumping fuel. On mine it keeps the fuel to the cp3 at 30psi and the rest is sent back to the tank.
Old Aug 13, 2007 | 12:23 PM
dogger's Avatar
Originally Posted by 3500eh
.... question here. when does lp actually lift the fuel? when starting, or all the time?
Unfortunately it is required all the time as it supplies fuel to the inlet of the high pressure, CP3, pump that feeds the common Rail (CR) to the injectors. The CP3 will not draw the fuel from the tank.
L8r,..............dogger
Old Aug 13, 2007 | 11:13 PM
Highway 4x4's Avatar
Took a look at mine today, mounted on the factory fuel filter. It still looks OK to me, LOL. If and when it dies I might just go factory again unless some one makes a direct replacement. I see no need to replace the factory fuel filter unit as I am stock.
Old Aug 14, 2007 | 01:50 AM
dogger's Avatar
No factory replacement 03 style LP
Unfortunately if you have to replace the lift pump on your 03 and DC does the replacement it will be an in-tank model as they discontinued the fuel filter mounted version. There is a fuel line adapter that mounts in place of the old fuel filter lift pump and then the fuel ine pick up and fuel level sending unit are removed and replaced with the "new & improved" in-tank lift pump.
L8r,.........dogger
Old Aug 14, 2007 | 05:51 AM
Locomotion's Avatar
Post
Originally Posted by Texan1983
are the intank lift pumps better? if i have an 04 and don't see a pump (not really sure what it looks like, but i am pretty sure one isn't there) and hear it running in the tank, does that mean it is an in tank lift pump? did some get these and others not? were they replaced this way?
They had in-tank pumps through 2004.5. I may have one of the last 2004.5 models and my lift pump is on the fuel filter housing. 2005 was the first year for in-tank pumps.
If you didn't get your truck brand new, somebody may have changed it out.
I'm over 46, 000 miles with no problems. But I've been considering the Glacier/Walbro system for a while now.
Old Aug 14, 2007 | 03:45 PM
Sprinter17's Avatar
Muted User
I wish I could get a reliable in tank pump, the design makes more sense. It only has to push, and it stays cooler in fuel. I paid big bucks to have a submersible pump put on my home, 150' under the ground. They beat the heck out of a pump sitting up in the yard, and it never looses a prime either. The reason a bet is because aftermarket folks would have a harder time getting them to fit several applications because size restrictions and float arrangements in the tank.
Old Aug 14, 2007 | 04:38 PM
nooska's Avatar
Can the in tank pump be repaired, I have a friend who is a mechanic and he repairs some of the in tank pumps on gasser cars...
How much is a replacement in tank pump from the Dodge Dealer??
jgarrett
May 9, 2011 12:18 PM
mstep3
23
Jul 27, 2010 02:22 PM
WhozNxtLS1
Mar 2, 2008 01:43 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
Jun 22, 2004 06:32 PM
