Lift pump keeps running
Old Jul 15, 2010 | 09:19 PM
Highway 4x4's Avatar
03, factory filter mounted lift pump, all stock. Power still good no other problems. Turn the key on and the lift pump used to run a few seconds then shut down when pressure is built up. Now it just keeps running. Is it going out? Warranty is out in one month. I know the fix is the in tank pump if its bad for $100 co pay. Could get the power seat fixed also. Advice on the pump???
Old Jul 15, 2010 | 09:40 PM
BLACKBEAR's Avatar
You show jump on it now ! If you will have it done out of your pocket the pump and labor is around 800.00+
Old Jul 15, 2010 | 11:35 PM
I have a spare new Geno's direct replacement on the shelf that I could put in myself. I hear the in tank units go a long time but when or if they go it's more work to replace them. If I have the in tank unit installed then my emergency on the road replacement is no good to me?
Old Jul 16, 2010 | 12:16 PM
mq105's Avatar
Could be the power supply/relay, and not the pump. Usually when the pump goes out fuel pressure suffers. What is your FP?
Old Jul 16, 2010 | 06:23 PM
I don't know FP, no gauges. No power loss felt even pulling TT. How much is the power supply relay and is it hard to R&R?
Old Jul 16, 2010 | 06:28 PM
Spooler's Avatar
Mine does the same thing. It runs for a while before it shuts down. It has done it ever since a reflash. Did it before I put my AirDog 100 on. If you let it run long enough, I beat it will shut down.
Old Jul 16, 2010 | 10:28 PM
mq105's Avatar
It sure sounds like the pump is fine, and that it is being commanded on. I would look at why the ECM is doing that now, when it previously was not.
Old Jul 16, 2010 | 11:24 PM
You guys are the bomb. I just got the reflash a few weeks ago. I timed the LP with key on, eng not started. Yep, 40 sec and off she goes. I am sure it used to be shorter, but all is well and the factory filter mounted LP lives. Thanks to you all.
Old Jul 17, 2010 | 01:55 AM
Bark's Avatar
90k miles and my OEM LP still works. But--I wanted mine to fail before the warranty expired but it wouldn’t. I almost bought the spare OEM that you got from Geno's but decided on the Raptor that I will put in when I get reunited with my truck in Sept. because with all the posts about LP failure on our year truck it seems it is just a matter of time. Only reason I am worried is that I routinely wind up a long way (5000 miles or more) from home.
tntdiesel
13
Jul 22, 2009 09:16 PM
Capp35
Jul 14, 2009 10:05 AM
sssmaly
Jul 13, 2007 12:57 PM
sssmaly
Jun 17, 2007 09:24 AM
97-12v
Dec 17, 2006 07:22 PM
