HE351 onto a 2003
Old Jul 15, 2010 | 09:41 AM
cLAYH's Avatar
HE351 onto a 2003
I've got a line on a HE351 turbo from a 2005 truck that I want to put on my 2003. I want it mainly for lower EGTS when towing, will I see a difference?
Is there anything else I need other than the turbo? Down pipe? The truck is being parted out so I want to everything I'll need.
Thanks!
Old Jul 15, 2010 | 11:06 AM
McGivern's Avatar
Turbo
You looking to buy the 05 turbo or already have it?
I have a Piers modified taken off my 2003 at 70K (modified at 40K). I now run a Garrett. The mod is good to +60HP and helps keep EGTs down. Here is the link.
http://www.pdrdiesel.com/products/PD...04-523-26.html
It would be a drop in with no mods required. Been sitting in my garage for a while with the intent to post to sell. I would take $400 for it (the mod alone is $600 plus core). Let me know if that would interest you.
Mark
Old Jul 15, 2010 | 11:24 PM
GreyTD's Avatar
The HE351 is a direct bolt on except for a few minor things. You need the longer stud bolts to go on exhaust manifold as the flange of the HE351 is thicker than the HE341. The shorter stud bolts need to be on the new (to you) turbo. For a cleaner look the electronic waste control should be removed and plugged. Here is a link to how some have done the swap,
https://www.dieseltruckresource.com/...ighlight=he351
Old Jul 16, 2010 | 04:16 AM
Dodgezilla's Avatar
It's a great mod. If possible, also get the cast elbow with the clamp for the downpipe, 4" downpipe, and full 4" exhaust from the donor truck. All that will help you get the most from the swap. I left the electronic wastegate solenoid in my turbo and just put a clamp on the hose leading to the wastegate. Works great!!!
Old Jul 16, 2010 | 02:14 PM
cLAYH's Avatar
Thanks for link to the master thread, I've moved my questions over to there.
Old Jul 16, 2010 | 04:32 PM
carl48's Avatar
dodgezilla you should remove the clamp. the turbo life will be shortened. it is best to hook the solenoid up to a 12 volt ignition hot wire this will give 32 psi opening. we cut ours into and make it mechanical
Old Jul 16, 2010 | 05:09 PM
Dodgezilla's Avatar
The turbo is not beaten on as my truck is only slightly modified. I am not concerned about hurting my turbo when it rarely ever sees 30 psi. The clamp will stay there until it rots away and falls off.......
Old Jul 17, 2010 | 10:20 AM
carl48's Avatar
i did not know you had the gauge. i do like the change to he351
converteddzlr
Sep 13, 2006 11:02 AM
SmokinDodge12V
Aug 1, 2006 07:19 PM
MoparRiggan
31
May 21, 2005 10:03 PM
signature600
Dec 14, 2004 06:05 PM
tenndiesel
32
Dec 26, 2002 06:43 AM
